hammering sound from gearbox or transfer box
15 May 2016 18:15 #166831 by mysterious
Hi all. plz need some help
I have suzuki jimny model 1999 manual gearbox.
no modification at all , still original . 3 years ago i fitted yokohama A/T-S 195/80/15R untill now tires are still new with full grip and no slipping.
uponce a time when I was angry I released the clutch pedal quickly in first gear so I heard only one hammer sound. I thought that i damaged the engine mount. I'm always driving in 2wd and im sure there
is a complete disengage from the 4wd.
after that when I'm trying to accelerate quickly sometimes I hear many hammering or knocking sound specialy if there is full grip on tarmac or if I'm uphill and trying to accelerate on 1st gear. last time I let RPM about 5500 on the 1st gear and shift quickly to 2nd gear while quick release the clutch pedal so I also listen that sound. I did that just trying to diagnose if it's from the 1st gear gears or the chain in the transfer gearbox.even while reversing in an uphill.
I think it's the primary shaft maybe.
THE SOUND IS FROM THE MIDDLE OF THE JIMNY AND I ASSUME IT'S LIKE SOME GEARS ARE BROKEN OR MAYBE A SLIPPING GEARS OR CHAIN( like the bicycle chain when slipping and not well engaged).
while driving on highway , put the car in neutral to listen if there is a noise in the rear differential. all is ok.
i need some help before i take my jimny to the garage cz maybe mechanic man will try to disassemble gear box or tranfer case.
any help is appreciated. thanks all
15 May 2016 18:28 #166833 by mlines
Sounds like the transfer chain is slipping, quite a common fault.
Cheapest fix is a transfer box from a scrap Jimny.
15 May 2016 18:32 #166834 by mysterious
chain is working alltime even in 2wd ? i mean it gets
a torque all time ??
15 May 2016 18:46 #166836 by mysterious
quote="mlines" post=166833]Sounds like the transfer chain is slipping, quite a common fault.
Cheapest fix is a transfer box from a scrap Jimny.[/quote]
Sir , u mean it's better to install a used complete transfer box. or get a new chain if possible ??
i asked the company for new chain they said it costs about 400$ and they don't have it and they should order it. btw i found only one transfer case in all my country in the scrap shop for 250$ . the owner shop told me it's from japanese broken cars and in very good conditions. i will try to replace it and i will reply on the forum if the problem is fixed.
anw special thanks from Beirut city in Lebanon for your quick reply
15 May 2016 19:01 #166837 by j999pre
Also check for a broken transfer box mount. The long one is a common problem.
Grey pick up Jimny
15 May 2016 19:07 #166838 by mysterious
yes i will. but i don't think it's the long mount. cz
it's not one hammer. the sound is sometimes 6 hammers sound. like the chain jumping on the gear teeth many times.. thanks again
Time to create page: 0.198 seconds
