Just finished my m16a conversion
- Steveolkinevel
29 Apr 2016 23:04 #166010
by Steveolkinevel
Just finished my m16a conversion was created by Steveolkinevel
This past week I've been plodding away with my m16a conversion and for those who are in 2 minds weather the go ahead with it or not I can say......... Don't even think about it, get one ordered asap! I can't belive just how bigger difference it's made, normal road driving now is just incredible, before my little 1300 was tired and sluggish beyond belief, even the slightest hill and I was down into 2nd gear and revving the nuts off it, but now I keep going for a 6th gear :laugh: it will set off in 2nd gear no problem and power up hills in 4th without a problem, 100% the best thing I've done.
It's even ticking over just perfect with the m16 throttle body and 1.6 idle control valve, at first it was ticking over at 1800 rpm and I went to my local machine parts place to try and get a 5 sided torx bit (it's not a ordinary torx bit on the control valve) which they diddnt have, came out started it up and it's ticking over just fine now!
not that I'm complaining.
Any way if anyone has any questions I'd be happy to help as it's all still fresh in my mind
Cheers steve
Cheers steve
- Thank you received: 225
30 Apr 2016 00:50 - 30 Apr 2016 00:55 #166011
by zukebob
Replied by zukebob on topic Just finished my m16a conversion
Very nice! Keep us updated on how it goes over time. Is yours a non-VVT? I have a 2015 JImny but in the Philippines they don't have the VVT engine. I have been considering the non-VVT M16A upgrade.
Last edit: 30 Apr 2016 00:55 by zukebob.
30 Apr 2016 07:44 #166019
by Busta
Replied by Busta on topic Just finished my m16a conversion
That's good to know about the throttle body! Might try swapping mine over.
- the_goshawker
30 Apr 2016 09:23 #166021
by the_goshawker
Replied by the_goshawker on topic Just finished my m16a conversion
propper job
30 Apr 2016 17:10 #166048
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Just finished my m16a conversion
Hi Steve,
This is definitely something I've been considering. I'm wondering if there's any difference between the swift sport and the grand vitara M16 apart from power output? Do the Jimny ancillaries fit on the M16 block, was there anything special you had to do or was it just swap over the bits from the M13 onto the M16? Any issues with the electrics/sensors?
30 Apr 2016 18:04 #166051
by minibbb
Replied by minibbb on topic Re:Just finished my m16a conversion
Best thing I've done to mine
Gordon you want a liana engine ideally if it's a M16A you're after. All the Jimny bits swap across.
If you search "liana" you'll find loads of info on it
Time to create page: 0.157 seconds
