jimny with automatic geardox
08 Nov 2015 14:25 - 09 Jul 2019 15:07 #155724
by safari
if u worry u die if u dont worry u still die so why worry
jimny with automatic gearbox was created by safari
what r the pro and cons for a jimny with automatic gearbox for offroad purpose so with lift and bigger tyres?
Last edit: 09 Jul 2019 15:07 by Lambert. Reason: Spelling
08 Nov 2015 20:22 #155759
Replied by helijohn on topic jimny with automatic geardox
Never took mine for serious mudplugging so I can't comment as I never felt the need to lift it etc. but as it was in standard form albeit with wide wheels it did fine.safari wrote: what are the pro and cons for a jimny with automatic gearbox for offroad purpose so with lift and bigger tyres?
08 Nov 2015 20:33 #155760
by kirkynut
Replied by kirkynut on topic jimny with automatic geardox
I think you may have more control over the throttle and progress with an automatic if you have lower low ratios by way of a rocklobster transfer box when using holding gears but the gearbox oil cooler needs to be replaced with a larger one or it'll overheat.
I've not tried it but Rhino Ray has.
08 Nov 2015 20:37 - 08 Nov 2015 20:37 #155761
Replied by mlines on topic Re:jimny with automatic geardox
Pros:
Your never in the wrong gear
Copes with different sized tyres without gearing change.
Torque converter does exactly what it's name implies
No clutch to fill with mud
I love autos for off roading
Cons:
Jimny autos like fresh new fluid regularly
Engine braking downhill is limited, to you have to lock it in first.
Sent from my Nexus 5 using Tapatalk
Cons:
Last edit: 08 Nov 2015 20:37 by mlines.
08 Nov 2015 20:43 #155763
I just love autos but Martin, tell us about lifts in Jimny autos. Easy or not?
Replied by helijohn on topic Re:jimny with automatic geardox
08 Nov 2015 20:46 #155764
Never done one but I cannot see why it would be different from a manual car, apart from if you do a body lift and have to play with the selector. I have seen one on a spring lift and it was fine. However, its no street racer!
The following user(s) said Thank You: helijohn
Time to create page: 0.110 seconds
