The Jimny that squeels!
  • murrayup
15 Sep 2015 15:05 #152016 by murrayup
The Jimny that squeels! was created by murrayup
Hi all
So, after fitting my cam sensor and looking for a crankshaft sensor I now have a squeaky motor.
Sounds like one of the pulleys. I fitted all new belts this time last year when I replaced the cam belt.
This always happens on startup even when warm. Squealing lasts for about 20-30 seconds then stops.
Very embarrassing first thing in the morning Q: is the fan belt too tight or too loose.
Any other ideas gratefully received.
Regards,
Ian.
15 Sep 2015 17:06 #152020 by BorisSpencer
Mine's done this for as long as I can remember. Tried slackening and tightening it, neither made any difference.
The following user(s) said Thank You: murrayup
15 Sep 2015 17:13 #152021 by facade
Replied by facade on topic The Jimny that squeels!
It will be the alternator belt, the high charge rate at startup makes it slip.
The belt is too loose, but could just be dry and slippery.
You can buy belt dressing, or just spray a bit of pledge on the ribbed side of the belt to quieten it down.
Most likely needs a new belt, the ones ECP sell are not the best.......
  • wombat
15 Sep 2015 20:40 #152031 by wombat
Replied by wombat on topic The Jimny that squeels!
My last jimny did that all the time, despite several belt changes and adjustments. As facade says its the high charge rate after start up. In the end i just lived with it. :( :(
16 Sep 2015 02:36 #152041 by Casey
Replied by Casey on topic The Jimny that squeels!
I thought mine was the belt but turned out to be the clutch release bearing. Worth checking as it's an easy adjustment as I found out here:
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=58519
  • murrayup
16 Sep 2015 09:52 #152051 by murrayup
Replied by murrayup on topic The Jimny that squeels!
Many thanks facade will try tightening it up this evening.
Regards,
Ian.
Time to create page: 0.287 seconds
