transmission control module
- jaybe
08 Aug 2015 19:25 #149440
by jaybe
Replied by jaybe on topic transmission control module
Hi, the car is in limp mode so I'm told, it is stuck in 2nd gear. Regards jaybe
- jaybe
09 Aug 2015 08:53 #149499
by jaybe
Hi, yes, that is the number on the box, year of car is 2002, has had diagnostic check, at a suzuki dealer, and they said it was transmission control module.regards jaybe
- jaybe
09 Aug 2015 09:01 #149500
by jaybe
Hi, when reading your message again, it says that your man has said that suzuki still have them, which makes sense, as they are still making jimney, but I was told by the suzuki dealer, no longer available regards jeanette
09 Aug 2015 12:57 #149512
by j999pre
Grey pick up Jimny
Replied by j999pre on topic transmission control module
I may have one but I'm away until the 24th
Grey pick up Jimny
- Mort
03 Nov 2021 00:38 #239821
by Mort
Replied by Mort on topic transmission control module
I have same intermittent module problems. Drops back to second while cruising some times any help would be appreciated and where is module located thanks. Cheers Phil.
03 Nov 2021 15:12 #239841
by fordem
Replied by fordem on topic transmission control module
Get a proper diagnosis done, in my experience the transmission controllers are not "high failure rate" items and the problems can be related to sensors, wiring and occasionally the solenoids in the transmission.
What model Jimny are you having trouble with?
Time to create page: 0.171 seconds
