Re:Wheels and tyres options, advice please.
05 May 2015 08:26 #143704
by minibbb
I run 215/75/15 KM2s on my jimny and love them. Road noise isn't an issue at all. I have a two inch lift and offset wheels. I'm lead to believe they fit fine without a lift however if you have spacers then they'll likely rub. It Hamas slowed the car down a little but IMO well worth it- it's epic off-road now
Replied by minibbb on topic Re:Wheels and tyres options, advice please.
05 May 2015 12:15 #143709
by Busta
Replied by Busta on topic Wheels and tyres options, advice please.
I went from standard 205/70 R15s to 215/75 BFG KM2s. The difference between 215/75 muds and standard tyres is about 6%. They make the car feel a little slower, but not drastically. I noticed it on the first few drives but after a week it seemed normal. The speedo goes from over-reading slightly to being spot on (when compared to a GPS). I had to remove the front mud flaps and one screw in the wheel arch where the wing and bumper meet, but my springs are fairly old and my jimny sits about an inch lower than normal. As a daily driver it is absolutely fine.
Re. spacers, IMO the only benefit is the look. They will not affect the turning circle. They make it easier to fit into ruts made by landrovers, which some see as a good thing. But if the ruts get too deep, the extra width of the spacers make it much harder to steer out of the ruts, or avoid them altogether so ultimately you are worse off.
The following user(s) said Thank You: fshdck
- fshdck
05 May 2015 13:03 #143713
by fshdck
Replied by fshdck on topic Wheels and tyres options, advice please.
That's what I needed to know. Thank you very much.
- ColinTheViking
26 Feb 2020 11:28 #219102
by ColinTheViking
Replied by ColinTheViking on topic Re:Wheels and tyres options, advice please.
What size are your rims on this photo?
26 Feb 2020 19:22 #219126
Replied by Daniel30 on topic Re:Wheels and tyres options, advice please.
Same as mine 7x15 with 30mm offset
- ColinTheViking
26 Feb 2020 21:21 #219128
by ColinTheViking
And would you be able to tell me how far they poke out? Would ET0 be in line with the wheel arch? I’ve heard that any offset destroys bearings.
Time to create page: 0.187 seconds
