Thinking of buying a diesel Jimny-a few questions
- OllieNZ
The joys of modern diesels......Adam32 wrote:
OllieNZ wrote: [quote="Adam32" post=142476
You need a mechanical pump for veg, common rail diesel engines don't really appreciate it.
Did not realise it was common rail, know nothing about that particular engine.
Adam32 wrote: So say if I went for the diesel jimny and assuming the transfer box is the same as on the petrol - would it be an electric selection transfer box? If so any idea if anyone does a manual leaver to convert this? One of the first thing I did when I got my Ssangyoung was remove the electric motor on the transfer box and fit a manual leaver mechanism that someone custom makes in the states. I just hate electrics and don't trust them. At least with something mechanical you know where you are. Anyone know if somone makes a custom solution for the Jimny transfer box?
It is my belief that the hole is in the floor with a screwed down cover plate for the manual transfer box and that all the mountings are the same. The internal plastic mouldings around it may differ though. So I believe if you got a manual old style transfer box and removed the cover in the floor that covers the manual lever's hole, you ought to be able to fit a manual box.
You will need the rubber seal for that hole also to stop wind noise and drafts and any differing internal plastics around the handbrake area. You'll have to cut a hole in the carpet for it to come through also.
My belief is based on seeing a user on here called Zukenutter from Australia fit a Rocklobster transfer box in his later push button transfer box Jimny. If he could do that, surely you can do the simpler conversion you speak of.
This all assumes that the prop lengths were the same between push button transfer box and manual transfer box cars. Otherwise props are easy and cheap to find but the one I would not be sure of is the transfer box to gearbox mini prop.
Anyone with knowledge of these bits?
- Adam32
kirkynut wrote: It is my belief that the hole is in the floor with a screwed down cover plate for the manual transfer box and that all the mountings are the same. The internal plastic mouldings around it may differ though. So I believe if you got a manual old style transfer box and removed the cover in the floor that covers the manual lever's hole, you ought to be able to fit a manual box.
Many thanks for this information, that's really useful to know. What year did they change from manual to electric? Were all the manual boxes the same? Also I would like to fit a transmission brake once I have done the conversion and believe Xbrake used to sell a kit. Were these kits for the old style boxes?
- Thank you received: 1931
- TomDK
X-eng make a transfercase brake for LR Defender. Not a Jimny or other vehicles.
But agree with 11/60, why? It's just another thing to break, especially due to the place it's mouted. It'll be the lowest point hitting rocks and dirt etc.
- Adam32
TomDK wrote: X-eng make a transfercase brake for LR Defender. Not a Jimny or other vehicles.
I thought they did make some Suzuki stuff - have a look at this link:
foundry4x4.co.uk/index.php?route=product...5_1757&product_id=80
I suppose it's all down to personal preference , but I really like the Xbrake stuff I saw on a few Defenders - tended to grip much better. Plus if you fit a transmission brake, for normal everyday driving it tends to be out of the way of all the mud and other rubbish, so less likely to seize. But I agree it is personal preference.
