smallest winch for self recovery in snow
- Asbojimny
18 Nov 2010 18:33 #6112
by Asbojimny
We fitted a rear winch by cutting hole in boot floor,welding some plate to underside of chassis and winch rope exits through the heavy duty bumper.
Replied by Asbojimny on topic Re: smallest winch for self recovery in snow
mkay wrote: the little winch is intriguing, the mount is exactly what i had in mind.
perhaps i should mount it in the boot and fit a fairlead in the rear door.
we'll see ho that little unit works i think though.
keep the ideas coming!...
18 Nov 2010 20:57 #6122
Replied by mlines on topic Re: smallest winch for self recovery in snow
There are a couple of things to remember about winches.
The pulling power (750kg) is the maximum pull. The pull DECREASES with each layer of rope on the winch, therefore the pull of a winch when only a short piece of rope is wound out is a LOT LESS than the quoted pull.
However, using a snatch block and creating a double pull DOUBLES the pulling power (but halves the winch speed). Also as a double pull spools more rope off the drum you are likely to have fewer layers of rope on the drum which also increases the pulling power.
Therefore it is possible with a little care to make the smallest of winches more powerful by spooling out as much rope as possible and doubling (or tripling!) the pull.
A few years ago a Landrover magazine recovered a Landrover with a "rope" made out of Duct Tape by creating a multiple pull ( I think it was in the region of 15 loops of duct tape (I don't know the word for 15 in the sequence double, triple, quadruple...)
- ooky_123
18 Nov 2010 23:05 #6127
by ooky_123
Replied by ooky_123 on topic Re: smallest winch for self recovery in snow
I have access to a Turfor winch .. but to be honest, the winch needs setting up correctly or it can be very dangerous.
Lots of copies and poorly maintained ones on ebay.
Plus you have to carry around a length of cable that isnt easily stored, sometimes oily cable.
on the flip side, a well maintained turfor will last a lifetime and you can easily pull massive weights with them due to the double clutch mechanism inside.
Time to create page: 0.208 seconds
