smallest winch for self recovery in snow
  • mkay
04 Nov 2010 18:25 #5722 by mkay
i need a winch for self recovery in snow ie. bellied out.
rearward facing on detachable mount to pull myself back to where i had traction
i need somthing small and light, i was thinking a supawinch UTV4000 as the jimny doesnt weigh much more that a fullsize kubota UTV.
how would be the best way to accomplish a detachable system?
my firt thought was remove the flange on the tow bar and have a thick plate L shape made to mount the winch on...but i want to keep my towbar useable...
and ideas? or practical advise?
  • ooky_123
18 Nov 2010 15:26 #6094 by ooky_123
Replied by ooky_123 on topic Re: smallest winch for self recovery in snow
Hi Lift ? ... if your just winching from snow, then you only really need to beable to move the weight of the vehicle and contents rather than 1/2 tonne of sticky mud!!!...
If you know how, you can winch using a Hi-Lift as a winch ... takes a while but for £50 plus roap... its good value.
Failing that, assuming your only winching out of snow when grounded, get the smallest one you can .... say a 750kg one .. just enough to get you rolling .. again, it wouldnt be sufficient for recovery from a muddy hole, but for simple hauling you off becoming beached in snow, it will probably work.
decisions decisions .....
  • Jamie
18 Nov 2010 15:38 #6098 by Jamie
even better than a Hi-Lift are the Tirfor style winch
reall portable and a lot easier to set up than a Hi-lift.....
However the Tirfor only does one job and the Hi-Lift is more versatile,
Saying that i've a Hi-lift and only used it once in four years and that was
for a tree stump!!! If you want one let me know, i could be persuaded to
sell it on,
Tirfor cgi.ebay.co.uk/Tirfor-Winch-Landrover-Of...&hash=item19c1001256
  • mkay
18 Nov 2010 16:15 #6102 by mkay
thanks for the replies, its good to know my logic is not ill logical.
a tirfor would be ideal for the time being, although i will definatly go electrical next year.
any ideas for a rear mounted tray on a vehicle fitted with a towbar?
i keep having them but it always requires me to have the winch offset to one side or even under the vehice, which is rather impractical
  • Asbojimny
18 Nov 2010 16:36 - 18 Nov 2010 16:43 #6104 by Asbojimny
Replied by Asbojimny on topic Re: smallest winch for self recovery in snow
I'm sure on e blag,there are small electric winches that loop over your tow bar. A simple power socket would make it de mountable in seconds.
cgi.ebay.co.uk/Toolzone-12-v-6-000Lbs-Bo...&hash=item2c5200d4d1
Or a bolt on plate like this...
cgi.ebay.co.uk/Winch-Universal-Tow-Ball-...&hash=item4142a1b04d
Last edit: 18 Nov 2010 16:43 by Asbojimny.
  • mkay
18 Nov 2010 17:48 #6109 by mkay
the little winch is intriguing, the mount is exactly what i had in mind.
perhaps i should mount it in the boot and fit a fairlead in the rear door.
we'll see ho that little unit works i think though.
keep the ideas coming!...
Time to create page: 0.171 seconds
