What do I need to make and fit breathers?
  • Yellostreak
17 Dec 2014 16:06 #132612 by Yellostreak
Replied by Yellostreak on topic What do I need to make and fit breathers?
you can do it on the floor but its easier on stands or ramps..
17 Dec 2014 16:15 #132614 by maverick
getting to the Breather on the top of the Transfer Case is a "joy job" (not) ..
Jalapeño, IISY?
17 Dec 2014 16:50 - 18 Dec 2014 12:17 #132621 by X8GGY
maverick wrote: getting to the Breather on the top of the Transfer Case is a "joy job" (not) ..
Isn't the gearbox even harder to reach?
Not done mine yet... must have a look see...
Edit 18/12/14
Just had a look underneath and could see the breather peeping out into the transmission tunnel, so I pulled the breather pipe's cap off it and measured it to gauge the internal diameter, and have ordered a reducer to fit into it to take the 6mm pipe that comes with Martin's excellent breather kit... I'll update my own build blog / thread when it arrives and I get it done B)
Last edit: 18 Dec 2014 12:17 by X8GGY.
  • Back in Black
17 Dec 2014 17:23 - 17 Dec 2014 17:25 #132626 by Back in Black
Replied by Back in Black on topic What do I need to make and fit breathers?
GuardianAngel wrote:
Benn wrote:
www.danbp.org/w/Extending_the_breathers_of_the_Suzuki_Jimny
I used this site tooooo.
Did mine on the floor in the front garden with hose pipe, jubilee clips and cable ties, no real problems, though I have a body lift fitted which I imagine makes it a bit easier to reach the top of the gearbox and transfer case?
No toilet roll tubes or double sided sticky tape though!!! Showing my age with edit :)
Last edit: 17 Dec 2014 17:25 by Back in Black. Reason: typo
17 Dec 2014 17:40 #132629 by jackonlyjack
Could anyone tell me if
G&t box is same diameter as diffs
cos I plan to use silicone hose
and need to order enough
thanks
  • GuardianAngel
17 Dec 2014 19:36 #132639 by GuardianAngel
Replied by GuardianAngel on topic What do I need to make and fit breathers?
jackonlyjack wrote: Could anyone tell me if
thanks
Check out the article link for some of the diameters:
Diffs are 1/2"
T-box is 1/4" and 3/8" (appears to have two breathers)
G-box - no idea it does not say :unsure:
