What do I need to make and fit breathers?
21 Dec 2014 08:35 #132930 by kirkynut
Jimnyash wrote:
Benn wrote: Well, I fitted the big Jimny kit for the diffs today and it all went nice and smoothly, even though I was quite nervous when tapping the threads needed!
Attachment not found
No issues with Swarf getting into the diff while tapping? If not, I may be tempted....
I don't fancy changing all the diff oil as well.
What's the problem with changing the diff oil? If you have not done it recently it will probably be due.
  • Yellostreak
21 Dec 2014 08:48 - 21 Dec 2014 08:49 #132932 by Yellostreak
Replied by Yellostreak on topic Re:What do I need to make and fit breathers?
Can you get a kit just for the diffs?
When I did mine I coated the tap in grease. Caught most if not all the swarf.
Done an oil changethis week and no issues!
Last edit: 21 Dec 2014 08:49 by Yellostreak. Reason: typo. dwarf!
  • Benn
21 Dec 2014 09:22 #132936 by Benn
Yup, the basic kit, which is the one I have is just for the diffs. Very easy to fit, even for a novice like me.
I didn't have any problems with the swarf, but I made sure I changed the oil afterwards.
  • Jimnyash
21 Dec 2014 16:46 #132958 by Jimnyash
Replied by Jimnyash on topic Re:What do I need to make and fit breathers?
kirkynut wrote: What's the problem with changing the diff oil? If you have not done it recently it will probably be due.
It has been done recently. Maybe I'll do the whole lot in the spring.
21 Dec 2014 17:30 - 21 Dec 2014 22:18 #132961 by X8GGY
Finished off my breathers today! Thanks to reading this and other recent threads on here about fitting breathers... it inspired me to have another look at my gearbox breather...
Lying on my back in the garage I could spot the breather poking out in the transmission tunnel... Strange, as I'd always read that getting to the gearbox breather was a real chore?
Closeup... there's just a little bit of rubber pipe on the breather tube and then a small plastic cap on it...
So I reached up and pulled the cap off, and used that as a reference to order a reducer - 8mm internal pipe to 6mm plastic tube to match what is supplied in Martin's / BigJimny's excellent breather kit...
The reducer fitted perfectly into the end of the existing breather rubber tube, and the tube supplied with Martin's / BigJimny's breather kit fitted in perfectly...
And the other end of the tube plugs into the manifold block I added to Martin's / BigJimny's breather kit (as my Rockwatt Rocklobster transfer box already had a 8mm elbow connected to it when I got it)
You may remember, the right hand 8mm black tube goes back to the transfer box, the 3 smaller 6mm tubes pointing down go to the front and rear axles, and now the gearbox breather, whilst the left one heads up to the snorkel's head -
And is neatly held to the genuine Safari snorkel with a couple of plastic P-Clips on the mounting bolts...
Breathers Complete! B)
As said above, I used Martin's / BigJimny's excellent breather kit, but added the manifold block as my Rockwatt Rocklobster box had an 8mm fitting already tapped into -
I've suggested to Martin that he could add this reducer / coupler to his kit, as it's a lot easier to just slip that into the existing breather rubber pipe? B)
Dave
Last edit: 21 Dec 2014 22:18 by X8GGY.
21 Dec 2014 17:36 - 21 Dec 2014 17:38 #132962 by X8GGY
Tapping the axles is extremely easy, easier than I thought it would be! -
Then the elbow connector just screws into the thread you've cut -
Breather is the right-hand blue tube, the other is the ARB's airline...
My diffs were already out for rear ARB airlocker / front LSD installations, so changing the oil was a necessity anyways...
It's probably wise to change your axle oils at the same time as fitting the breather tubes, particularly if you've already been offroading / greenlaning without "proper" breathers fitted...? :blink:
Last edit: 21 Dec 2014 17:38 by X8GGY.
Time to create page: 0.189 seconds
