heater problems
- highball
30 Nov 2014 18:04 #131083
by highball
heater problems was created by highball
sorry if this is a repeat, typed up earlier and cant find it. anyway my blowers only blow cold air, i think the matrix is ok as the housing is really hot, i think the levers arent turning a flap ? just a guess as i have no idea of how its looks inside the housing. any diagrams or instructions on how to remove and reinstall housing would be really great. thanks in advance.
30 Nov 2014 18:41 #131091
by kirkynut
Replied by kirkynut on topic heater problems
If you look up under the dash from the driver's side footwell you will see a white lever nearest to the gearlever side.
From reading on here, this often gets caught by feet and pulled off its mounting. This controls the hot/cold I believe.
- highball
01 Dec 2014 11:36 #131182
by highball
Replied by highball on topic heater problems
Thanks kirkynut problem solved had to use pliers, stuck on hot for now.
- jfkenpoman
19 Jan 2019 18:08 #201162
by jfkenpoman
Replied by jfkenpoman on topic heater problems
Hi mate sorry to hijack this post, just got another 2005 jimny and heater stuck on hot wherever I put the temp control level, looking under the dash as suggested I can move the white level which the next gives me cold air. There is another white plastic lever above it with a cable attached, am I right in thinking that the cable is attached to the heater/cold air lever?
- jfkenpoman
26 Jan 2019 08:38 #201722
by jfkenpoman
I cannot find a cable to the white lever, does anyone have any pictures/ diagrams showing the cable run etc thank you guys in advance
- Thank you received: 2004
26 Jan 2019 08:42 #201723
Replied by Lambert on topic heater problems
When I had to undo mine it sproinged off up into the depths of the back of the dashboard, took me an age to find and fish it back out. Good luck.
Time to create page: 0.127 seconds
