Electric vs manual transfer box differences
12 May 2014 12:14 - 12 May 2014 12:16 #114938
by Busta
Electric vs manual transfer box differences was created by Busta
In terms of replacing one with the other, what are the differences between the newer and older Jimny transfer boxes?
Can the electric controlled boxes be converted to manual or is the casing/ shift mechanism completely different?
Can you easily install a 2005+ transfer box into an older jimny?
Any pictures would be appreciated.
Last edit: 12 May 2014 12:16 by Busta.
- jtayl153
12 May 2014 14:34 #114950
by jtayl153
Replied by jtayl153 on topic Electric vs manual transfer box differences
as far as I know, the gearing is slightly different. Im sure it's been done and could be done again, but I am under the impression that, similar to VVT vs non VVT compatibility, electric and manual transfer is the same.
Could be wrong though.
I like my electric anyway.
12 May 2014 17:23 - 12 May 2014 18:05 #114983
by Busta
Replied by Busta on topic Electric vs manual transfer box differences
The gearing is different.
The 2005+ manual boxes are higher in both ranges so not much good.
The newer auto box, however, has the same ratio in HI range as the older boxes, but LO range is 23% lower. This would be the main reason for changing, as well as the newer models having a stronger chain.
For those of us running near-standard tyre sizes and/or bigger engines, it would mean better LO range without affecting the cruising speed. (A rocklobster drops HI range by 10%)
An even better combination would be the HI range gears from a newer manual car, LO range from a newer automatic and the diffs from a newer manual. If possible, this would give near-stock HI range and 35% lower LO range!
Last edit: 12 May 2014 18:05 by Busta.
- Docmartin4x4
12 May 2014 18:56 #114990
by Docmartin4x4
Replied by Docmartin4x4 on topic Electric vs manual transfer box differences
Right bear with me on this guys............so if I fit a transfer box from a 2005 on jimny to my 2006 jim the HI range(standard 2 wheel drive and standard 4 wheel drive) will be the same but when in LO range it would give me a 23% reduction! which will help emensely if I fit bigger tyres ( was thinking of 235 75 15).
Mart
Mart
12 May 2014 19:35 #114996
by Busta
Here's the info I'm working with for the ratios.
www.bigjimny.com/images/documents/transferboxratios.pdf
Mart, if your Jimny is a 2006 manual then you can do a straight swap with a 2005-on auto transfer case and get lower ratios in both HI and LO range.
I'm surprised nobody knows about converting the electric range shift to a gearstick?
- jonesyba420
12 May 2014 22:44 #115021
by jonesyba420
Replied by jonesyba420 on topic Electric vs manual transfer box differences
Surely it would be easier to fit a 3 way switch on the dash?
Time to create page: 0.094 seconds
