Suzuki kingpins and seals vs OEM?
  • GuardianAngel
01 May 2014 18:58 #113930 by GuardianAngel
Replied by GuardianAngel on topic Suzuki kingpins and seals vs OEM?
Sandspider wrote: Cheers chaps.
Apparently they do need to do the swivel seal as well, and the whole lot will only cost 70 or 80 from Suzuki. The mechanic did say that he's used the big Jimny ones before and they do wear out quicker...? Not sure about that, but if the whole lot needs replacing I'll just let em do it.
He is just bull shitting you. All garages do. They want to make as much profit as possible.
  • mc_nebula
01 May 2014 19:05 #113931 by mc_nebula
Replied by mc_nebula on topic Suzuki kingpins and seals vs OEM?
The BigJimny ones are made by Koyo, exactly the same as the ones Suzuki use in the factory. My original Kingpins that I replaced were Koyo ones, I have the BigJimny ones in now, no issues. The swivel joint seal is a dust seal, not an oil seal like on a Land Rover. It's not a requirement of a kingpin change to replace it. I've done both kingpins on my car and not replaced either swivel seal. If I'd read what was posted here and the garage kept that story up, I'd take my car and trade elsewhere. (actually, I'd do it myself, I did both in an afternoon...)
  • GuardianAngel
01 May 2014 19:11 #113932 by GuardianAngel
Replied by GuardianAngel on topic Re:Re: Suzuki kingpins and seals vs OEM?
mc_nebula wrote: The BigJimny ones are made by Koyo, exactly the same as the ones Suzuki use in the factory. My original Kingpins that I replaced were Koyo ones, I have the BigJimny ones in now, no issues. The swivel joint seal is a dust seal, not an oil seal like on a Land Rover. It's not a requirement of a kingpin change to replace it. I've done both kingpins on my car and not replaced either swivel seal. If I'd read what was posted here and the garage kept that story up, I'd take my car and trade elsewhere. (actually, I'd do it myself, I did both in an afternoon...)
Exactly. Does the mechanic own a Jimny and has he compared both makes? I doubt it.
  • Sandspider
01 May 2014 21:46 #113949 by Sandspider
Replied by Sandspider on topic Re:Re: Suzuki kingpins and seals vs OEM?
Thanks fellas
The mechanic will fit the big jimny ones if I prefer. But he said he's fitted them several times before to his sister's Jimny, and they've always needed replacing by next MOT. Then last year he fitted the suzuki ones and they were still fine this year.
He said the swivel seal needs doing as well as the half shalf seal. When I asked why as it's only a dust seal he said something like oil gets from the half shaft seal out past the swivel seal...? Didn't really make sense. But they've told me before when stuff didn't need doing so I don't think they'd be out to con me - maybe just erring on the side of caution and replacing it all while they're in there.
Does the swivel seal wear, and does replacing it make any difference if it is just a dust seal?
Cheers.
02 May 2014 20:02 #113994 by Basketcase
I only changed my dust seals as they had actually split if they're in one piece don't bother....in fact I at first didn't change then although they were split I changed them at a later date it made no difference really, where in country are you? Someone on here may be able to do the kingpins for you at a better price with bigjimny parts?
  • Sandspider
02 May 2014 20:28 #113998 by Sandspider
Cheers. Maybe next time, I would like to give it a go. I'm in the southwest.
Spoke to the garage again today and they're going to do whatever needs doing with 45 quids worth of Suzuki parts - I assume that doesn't include the swivel seal, but I'm not bothered about that. I'll see what the result is like, and maybe do the other side myself.
Time to create page: 0.211 seconds
