4" suspension lift, 3" body lift?
  • mudman
14 Dec 2013 15:45 #95958 by mudman
Replied by mudman on topic 4" suspension lift, 3" body lift?
idiotmobil wrote: im on 3" lift and 235 75 15 (29") they do me ok mite step up to 31s but my tyres are near new
Do the 235s catch im thinking of 235/70/16 still 29" but I want to go a bit wider
  • idiotmobil
14 Dec 2013 16:15 - 14 Dec 2013 16:16 #95970 by idiotmobil
Replied by idiotmobil on topic 4" suspension lift, 3" body lift?
Do the 235s catch im thinking of 235/70/16 still 29" but I want to go a bit wider[/quote
Ive done some trimming and offset wheels no rubbing at all I also had same on a 2" lift and no rubbing iver
Last edit: 14 Dec 2013 16:16 by idiotmobil. Reason: added
  • TomDK
14 Dec 2013 16:35 #95977 by TomDK
Replied by TomDK on topic 4" suspension lift, 3" body lift?
235/70/16 are no wider than 235/75/15.
14 Dec 2013 16:59 #95984 by kirkynut
Ok, let's get some clarity here as I think poor Bibby is possibly getting so many opinions it's getting confusing.
You want bigger tyres, so you need a lift. Go with the 4" lift kit from ORA. It's a very good, proven, comprehensive and in the long run cheaper way or doing it, assuming you have the money in one go, which I assume you do as you asked about it.
A 4" lift is a big one in 4x4 terms for any vehicle. You will raise your centre of gravity a lot so the vehicle will be more likely to topple over. You don't want to add to it with a body lift if you don't have to.
The size of tyres is a tricky one and you want to buy right once rather than buy a set & decide they are too small. Tyres are not cheap! I assume you are going to offroad sites.
There are many opinions on tyre size, as you have seen from the replies you've seen.
Are you driving it on the road? If so how far?
I'll come to gearing in a minute but if you want to be able to drive at 50 mph + and maintain it properly on an incline (hgv's do 65 mph and it's scary having them up your arse on a motorway in an ickle Jimjam), you don't want to go much bigger than 29-30".
Others may do it on 31" and be happy but my tyres are 29.75" (malatesta kaiman in 215/80/15) and mine is just about manageable.
If you know you'll never do motorways or dual carriageways for long or trailer it, it's not a worry.
Offroad, yes 31" will be better than anything less as you have more ground clearance, but do you need that much? I argue you don't. I also argue you will get fed up with breaking CVs.
My opinion, and that's all it is, is that the malatesta kaiman in 215/80/15 is the optimum tyre for a Jimny on an offroad site. It gives enough ground clearance with a tread pattern that grips & will not break CVs too often.
You can retain your standard wheels with 215/80/15 too. I'm not sure what size you need wider wheels for after this but that will obviously add to your expense.
If you want even bigger you could get some 16" grand Vitara wheels for 16" tyres & the sizes that are offered in that size.
Now the gearing question. You have indicated you want tyres in the bigger range. You will need a rocklobster for lower low range gears offroad or you will burn your clutch out quickly.
The gearsets you can get for your standard transfer box retain your chain driven transfer box, which is deemed to be weaker than the SJ transfer box the rocklobster is made from, which is all gears and no chain.
Rocklobsters whine somewhat due to old gears mixing with new ones. That's the way it is, you will have to accept it. How much is down to luck & how the new and old gears mesh.
Read the how to guide on the main Bigjimny site under information for fitting an SJ transfer box and send a pm to rockwatt on here who will supply you with the rocklobster transfer box & fitting kit for the box & speedo drive but not the propshafts you need and possibly not the flange you need.
Alternatively ORA can do one for you and they sell the flange you need new for about £80. Not cheap but needs must sometimes.
Both rockwatt & ORA will be similar in price & will quote you. Who you pick to build your rocklobster is up to you but rockwatt was my choice.
A rocklobster gives you slightly lower high range too. Helping on the road with those bigger tyres.
So in short, you will need to pick the bones out of peoples opinions to decide on tyre size. You will need a rocklobster and nothing else will do. A 4" lift on it's own ought to be plenty.
I hope this has helped mate.
  • TomDK
14 Dec 2013 17:26 #96000 by TomDK
kirkynut wrote: Ok, let's get some clarity here as I think poor Bibby is possibly getting so many opinions it's getting confusing.
Agreed, and well written :)
Just one thing to add.
All shocks ORA, bits4vits, Jimnybits, Bigjimny shop and so on are what's considered cheap shocks. They're meant for bigger heavyer trucks, usually american. They have their limitations, and are not suitable for fast competition.
I have a complete ORA 4" suspension lift, and fairly happy with it. just that the front shocks are now way hard enough for a heavy front with winch, bumper and so on, not for competition use.
Just to let you know that there are limitations. If you want better shocks, look at Bilstein. I've found some for universal fitment, that can be valved to exact specification. They're not cheap. But woth considering, if you plan on doing competition. www.bilsteinus.com/products/truck-off-ro...it-remote-reservoir/
14 Dec 2013 17:57 - 14 Dec 2013 17:58 #96022 by kirkynut
I've had pro comp shocks have their oil froth up rendering them useless until they cool down and sort themselves out after prolonged heavy offroading. Generally for most peoples use I think they are adequate though Tom. I suspect you use yours a bit more than most!
By the time you've washed up & had a tin of pop at the end of a pay & play day, the rough country shocks sold with most kits nowadays should be fine for the journey home.
Perhaps if it's a concern, speak to Rob @ ORA when ordering to see what shocks he advises for the given application, winch, no winch, speed events, non speed events etc... Speed events in a Jimny though!
Last edit: 14 Dec 2013 17:58 by kirkynut.
