Help desperately needed. Power Loss.
- Janey
24 Oct 2013 17:33 #87760
by Janey
Help desperately needed. Power Loss. was created by Janey
I love my 2001 Jimny and have not had a spot of bother with it in 2 years until Quikfit fitted me a new exhaust! which even though I am not mechanically minded I cannot see a connection between that and the problem that has developed. If I go over 65 mph I will suddenly lose power. Lights on dash flash, no accelerator pumping works, I have to fling on the hazards and make my way to the edge of whatever road I am on and stop. Turn off the ignition, she starts up straight away and then it will re occur anything between 400yds or 40 miles even doing between 10 and 40 mph. It is highly dangerous and quite nerve racking. Left over night it will go away and not happen again until I next try to go over 65. On Saturday it happened 11 times in 3 miles after the initial 65 mph and I virtually bounced into the airport parking. 4 days later picked her up, not a problem however I kept to 50 mph just in case. The first time it happened I had RAC follow me 30 miles on the A1. Of course it didn't happen. I have had her in a garage running diagnostics, nothing. I can't go every where at 50 mph. There have been 6 months between the first time and this time mainly because I have been doing short trips just back and forth from work in built up areas and when it happened again this weekend I realised it was the first time I had gone 65 since that last time. I don't know what to do
Please, has anyone any ideas, I am quite desperate.
- jonesyba420
24 Oct 2013 17:48 #87765
by jonesyba420
Replied by jonesyba420 on topic Help desperately needed. Power Loss.
Crankshaft position sensor maybe?
Located on the left side of the block under the alternator (if your looking from the front) pleanty on it on here buddy.i had a similar sounding issue and a new sensor solved it, theres a test you can do: first you need to locate the sensor in question then you need to make sure you have a squirty bottle of water to hand in the jimny, once youve located the sensor and are armed with a squirty water bottle take your jimny out for a drive and try cause it to fault (drive it hard and do whatever your doin when youve experienced the problem) when the fault occures pull straight over leave it running regardless how rough it sounds pop the bonnet and squirt water on the sensor if normal running resumes thats the culprit.the sensors overheat when they get old causing running problems.
If I drove slow ie 50 like your saying it was fine as soon as I pushed it for any length of time the sensor would overheat and cause power loss flashing needs and the rev counter would go mental.
- gaz3359
24 Oct 2013 18:25 #87774
by gaz3359
Replied by gaz3359 on topic Help desperately needed. Power Loss.
Like jonsey said sounds like a crank sensor,usualy ok when cold then start playing up when warm,and its quite common so worth changing it by sounds of it.
- markyp2000
24 Oct 2013 18:34 #87777
by markyp2000
Replied by markyp2000 on topic Help desperately needed. Power Loss.
Is it a hard or soft top as the crank shaft and cam shaft sensors are in different places it could be a lambda sensor or just a shit exhaust from shitfit i bet you learnt your lesson and wont go back there
- jonesyba420
24 Oct 2013 21:09 - 24 Oct 2013 21:11 #87814
by jonesyba420
forgot to mention that my bad.soft top one is on the front of the block I belive (not 100% as mines a hard top).
markyp2000 wrote: Is it a hard or soft top as the crank shaft and cam shaft sensors are in different places
Last edit: 24 Oct 2013 21:11 by jonesyba420.
Time to create page: 0.098 seconds
