fuel lines
  • rut
18 Oct 2013 19:33 #86922 by rut
fuel lines was created by rut
Evening everyone
What's the best fix for corroded fuel line? they are looking a bit on the ruff side just were they turn up to the tank the rest is like new, anyone ever joined a bit in and if so how did you fit it to the plastic pipe?
or am i looking at buying new pipes, and if so any ideas were to get some rather than from my local suzuki dealer who are wanting near to £100 for 2 pipes and they say they don't do the third one,
iv plenty of copper pipe and the front just go's into a rubber hose by the looks of it,
its that copper to plastic at the back thats the problem.
cheers rut
  • 410shotgun
18 Oct 2013 19:37 #86923 by 410shotgun
Replied by 410shotgun on topic fuel lines
just fit plastic pipes is the best
copper is ok but harder to fit
or cut out the bad pipe and put rubber pipe in
  • rut
18 Oct 2013 20:13 #86931 by rut
Replied by rut on topic fuel lines
plastic pipe would be good but how would i join it to the tank from what i hear the original last 18" or so of plastic pipe is push fit to the tank,
as for joining it were its corroded, the corroded part is were it joins the plastic,
cheers rut
  • helijohn
19 Oct 2013 17:21 #87054 by helijohn
Replied by helijohn on topic fuel lines
How bad is the corrosion as if it is only superficial clean them up and coat with a covering.
  • 410shotgun
20 Oct 2013 19:15 #87238 by 410shotgun
why not use them push fit conectors
on the plastic pipe should be some on ebay
if the pipe is the same size shoul be fine
most cars have push fit pipes now on fuel pipes
Time to create page: 0.094 seconds
