Manual Hubs
  • JAGM
03 Oct 2013 09:27 #85053 by JAGM
Manual Hubs was created by JAGM
I am thinking about replaceing the Vacuum Hubs with Manual Hubs. However, I would like to know what happens if I am driving on a country snow-covered road with the hubs locked and I come to a major road junction which has a roundabout which I must cross to continue on the country road on the other side of the roundabout. The Roads Service have cleared and gritted the major road and roundabout and it is wet but grippy tarmac (this scenario exists in two locations on my way to work). Will the transmission suffer if I drive throught the roundabouts with the hubs locked and does this mean a stop to unlock the hubs before proceeding and then another stop to lock them once the roundabout has been negotiated? Answers would be appreciated before I change hubs (BTW, my Vacuum Hubs are working perfectly - I have just read so much on this forum about Manual Hubs that I thought I should look at them).
Thanks,
JAGM.
  • vitara_mad
03 Oct 2013 10:00 #85054 by vitara_mad
Replied by vitara_mad on topic Manual Hubs
you will not need to unlock them
  • jonesyba420
03 Oct 2013 10:29 #85055 by jonesyba420
Replied by jonesyba420 on topic Manual Hubs
I to am abit confused when it comes to manual hubs. As you said do you have to stop to lock unlock every time you go from 2 to 4 whell drive or visa versa? I spend most of the time in 2high or 2low when laning and then just pop it into 4x4 when a tricky bit is coming up, with manual hubs do yoy have to get out in this situation to lock the hubs?
guessin with manual hubs a 2 low switch wont work so id lose being able to use low range in 2 wheel drive?
  • JAGM
03 Oct 2013 10:58 #85056 by JAGM
Replied by JAGM on topic Manual Hubs
Thanks for your reply vitara_mad. If I drive around roundabouts with the Hubs locked on tarmac, will that not create severe transmission wind-up which will ultimately damage the transmission???? I have very limited understanding of how it all works so excuse my ignorance. I guess what I am asking is, what is the difference between driving on tarmac with the Vacuum Hubs locked compared with Manual Hubs locked. Do the Manual Hubs compensate for this in some way and allow for alternating between tarmac driving and snow driving??
Thanks,
J.M.
  • Dave cc
03 Oct 2013 11:10 #85058 by Dave cc
Replied by Dave cc on topic Manual Hubs
You can happily drive on Tarmac roads all day with your hubs locked up will not give you any transmission wind up it is meant to be a fuel saving wear saving device that just stops you 1/2 shafts turning and is ment to aid fuel economy which is total horse shit Land rovers of old never had free wheeling hubs until later in life and shared the same part time 4 wheel drive set up as a Jimny
So in short lock them at the start of your green laning day and unlock them at the end :)
  • JAGM
03 Oct 2013 11:12 #85059 by JAGM
Thanks,
J.M.
