fuse info
- winter
- RichiesJimny
- winter
the t-max die which come with my split charge shows no fuses but the one on web shows fuses which are 200ah ????
fooking wiring i hate it lol
gerrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
- winter
10ah fuse on that cant be right surely
Rhinoman wrote: Fuses are there to protect the wiring, the fuse should be sized to blow before the wiring catches fire. You need to decide on the loading, select the wire and then select a fuse to suit. If for example, you have a 90W Alternator then the maximum short circuit current would be approx. 90/13.8 = 6.5A, so a 200A fuse is never going to blow. If it shorts the battery to ground then will the fuse blow before the relay?
- RichiesJimny
