Modulars
  • ritchie
23 Sep 2013 16:04 - 23 Sep 2013 16:06 #84109 by ritchie
Modulars was created by ritchie
Similar topic to whats been posted before but i havent came across anyone mentioning offset wheels of this degree so here it goes..........................
Im waiting for my 2.5" mud skipper suspension lift kit to arrive, however Im dying to buy some modular wheels to fit once the lift is done.
I'm really tempted to go for a set of 15x7 ET - 30.
Question is, has anyone got modulars fitted with this much negitive offset and if so Are they good and would you recomend them or have you had nothing but bother. I beleve the standard alloys on the jimny have a +5 offset (i read it somewhere) so i think that would give me an inch (25mm) more tyre stick-out than the standard wheels. which sounds good to me. And id imagine the handling would be improved as much as with spacers - but i really dont know.
If i can just use these offset wheels instead of 32mm spacers or whatever I will go ahead and purchase them. and then start thinkin about tyre sizes. which is a another head scratcher. I like my Cooper AT'S standard size 205/75/15 (see in pic) there good in snow, moderate offroading and dont notice any change on the road but think id need bigger ones once its lifted.
Also cant decide if i want to remove the ABR or not. ahhhh too much options. :laugh:
Any advice or similar experiences would be awesome.!!!!!
Last edit: 23 Sep 2013 16:06 by ritchie. Reason: wrong picture
  • helijohn
23 Sep 2013 17:51 #84118 by helijohn
Replied by helijohn on topic Modulars
ritchie wrote: Similar topic to whats been posted before but i havent came across anyone mentioning offset wheels of this degree so here it goes..........................I'm really tempted to go for a set of 15x7 ET - 30.
I can't speak for modular wheels as mine are one piece but I have 7x15 alloys with a fair amount of offset. I did measure the backspace one time but I've forgotten all that now (it's been a few months! :laugh: ). When fitted my tyre's tread is just covered by the edge of the wheel arch. I think it is either 1" or 1½" more offset than standard steel wheels.
www.bigjimny.com/index.php/forum/6-jimny...n-7x15-rims?start=24
  • idiotmobil
23 Sep 2013 17:57 #84120 by idiotmobil
Replied by idiotmobil on topic Modulars
mine are 235 75 15 7inch wide with a ressonable offset dont know what number but they stick out about 2 inch past the arches im on a 3" lift with trimed arches and bumpers and alls good with mine
  • RichiesJimny
23 Sep 2013 19:54 #84141 by RichiesJimny
Replied by RichiesJimny on topic Modulars
You'll probably find most 7x15 modulars to fit the jimnys are -5 or -7 offset which fill the arches nicely, if you then add spacers you'll push them outside the arch which is illegal.
215/75's are slightly bigger than 205/70's and do fit with only a very small trim of the arches. 235/75 raise the gearing to much and really need a 3inch lift and also arch triming.
Anti rollbar could stay on if your only doing mild laning if your doing rock climbing or very rough tracks removing the anti rollbar does help.
  • helijohn
23 Sep 2013 20:08 #84147 by helijohn
  • ritchie
24 Sep 2013 10:47 - 24 Sep 2013 10:58 #84198 by ritchie
Replied by ritchie on topic Modulars
Thanks guys,
I've just bit the bullet and bought the modulars from jimny bits shop.
Thanks helijohn for your info. Much appreciated. I read ur links and think it might be a case of see how my 205s sit with the new modulars then take it from there.
But Thinking 215/75s will be the best option. Du think my cooper discoverer ats 205/75 would be too small for the 2.5 lift?
I'll put up pics once the work is done.
Last edit: 24 Sep 2013 10:58 by ritchie. Reason: Made a mistake again
