How do I locate the high beam wire?
- rexthecat
18 Sep 2013 00:11 #83530
by rexthecat
How do I locate the high beam wire? was created by rexthecat
Hi all, is the high beam wire easy to spot to connect to spotlights via a relay?
Cheers!
Cheers!
- Jimny_Aus
18 Sep 2013 02:16 #83531
by Jimny_Aus
Replied by Jimny_Aus on topic How do I locate the high beam wire?
get a test light remove the plug from your headlight and test power with high beam on and off.... should do the trick....
- iloveics
18 Sep 2013 09:01 #83548
by iloveics
Replied by iloveics on topic How do I locate the high beam wire?
I believe its the top wire going to the bulb, check with a multimeter. There earth switched so you want to earth the low current side of the relay via the high beam wire. i can do you a wiring diagram if you want.
- markyp2000
18 Sep 2013 09:41 #83549
by markyp2000
Replied by markyp2000 on topic How do I locate the high beam wire?
You cant wire spot light in like that as thay are switched earth NOT switched live use the search secrion or in the yellow posts at the top of the main page
- rexthecat
18 Sep 2013 11:57 #83555
by rexthecat
Replied by rexthecat on topic How do I locate the high beam wire?
Cheers fellas, I think I've spotted the wiring diagrams on here for negative switching so all should be OK. Is it the case in the UK if spots arnt wired to main beam their an MOT fail?
Ta
Ta
- markyp2000
18 Sep 2013 12:55 #83563
by markyp2000
Only the abligtry lights must work for the mot
Time to create page: 0.182 seconds
