MOT shaker rig
- Dave cc
16 Sep 2013 17:35 #83383
by Dave cc
MOT shaker rig was created by Dave cc
Took my Hilux in Saturday for the annual MOT and actually watched the bloke while he did it have had a noise coming from the O/S/F suspension so was a little concerned but passed with flying colours.
What I did notice is they no longer put a bar under the tires and lift the suspension as they used to he did the shaker rig thing jacked it up and checked for wheel play as i would expect.
Anyway decided to have a look for the mysterious noise when I got home so jacked up the front and pry bar under the wheel and lifted the suspension slightly only to reveal; a totally knackered top ball joint.
In my eyes I am sure the guy at the MOT station did everything as he should have as when the suspension is hanging you cannot feel that the top joint has failed only lifting it with the bar under the wheel revealed it.
Anyway to cut a long story shortish have ordered a pair of joints from Roughtrax £40 delivered bargain and will fit them before it goes out on the road again just seems this shaker rig thing has come into use but really didn’t show the fault as where doing it old school did so much for progress
- markyp2000
16 Sep 2013 17:45 - 16 Sep 2013 17:50 #83384
by markyp2000
Replied by markyp2000 on topic MOT shaker rig
Thay are shacker plates to test lower ball joints arms etc on a one man test lane as there called but your still ment to do a manual check im sure of it
Im sure supergaz will know as he works for gemco
Last edit: 16 Sep 2013 17:50 by markyp2000.
- supergaz
16 Sep 2013 19:40 #83400
by supergaz
Replied by supergaz on topic MOT shaker rig
This is the equipment I deal with
This video shows how the steering/suspension joints are inspected on big stuff ( ATF station in Chelmsford demonstrated by "Jesus" )
www.gemco.co.uk/product/bm53000-commercial-shaker-plates/
This is what is found in car MOT stations for cars/vans upto 3500kg
www.gemco.co.uk/product/atf-turn-plates/
Another version of this may be found on a 4 post lift.
Also you can get suspension testers which will shake the suspension as if you were going down a bumpy to find faults in suspension, found mainly in BMW dealerships, This is basically a vibrating plateeeeeeeeeeeeeeeeeeeeeeeeeeeeee
- Dave cc
16 Sep 2013 20:46 - 16 Sep 2013 20:47 #83412
by Dave cc
Replied by Dave cc on topic MOT shaker rig
Wasnt any where as posh as that looked like it was a add on to the 4 poster ramp was air operated and just did a slight rotational movement and was only under 1 wheel was defo air operated as nearly shit myself when the 100yr old compressor in the corner started up :woohoo:
Last edit: 16 Sep 2013 20:47 by Dave cc.
- supergaz
16 Sep 2013 20:53 #83414
by supergaz
That would be a side slip, it only pulls on one side as it does it pulls on the opposite side. It would show up faults such as kingpins, steering joints and bushes to wishbones on cars.
- Dave cc
16 Sep 2013 21:02 #83415
by Dave cc
Honestly mate he was in there wth his inspection lamp im sure it didnt show up the worn out top joint will post a picture of it when i change it i reckon its got 4mm of lift in it when you put a bar under the wheel
Time to create page: 0.087 seconds
