Question about different tire sizes
- ellisthomas
15 Sep 2013 01:31 #83191
by ellisthomas
Question about different tire sizes was created by ellisthomas
Hi. Just found this forum when looking for information on tires for a Jimny. I've had the idea of turning my Jimny into a proper off road vehicle one day when it's not my main vehicle. It's my first car and in all honesty I don't ever want to sell it because it's such a great little character and I would be worried about how someone would treat it. You wouldn't want to sell your dog would you? Anyway, on to my question.
I need new front tires which are currently the standard 205/70 R15 size and I have the same size on the rears. The rears still have a lot of miles left so i'm not going to be replacing them. My question is can I get 195/65's on the fronts if the rears are 205/70? Would I be correct in thinking any size would be ok if the rim size is 15?
Thank you to anyone who has read this.
15 Sep 2013 07:02 #83200
by kirkynut
Replied by kirkynut on topic Question about different tire sizes
You need to have the same size tyres front and rear or the first time you put it in 4wd it will wind up the transmission so much it will not be able to loose the tension even on a slippy surface and make something break in the transmission.
Do you mean 195/80/15's?
You will either have to stick the the size you have or change them all.
- ZookFastback
15 Sep 2013 07:13 #83202
by ZookFastback
Replied by ZookFastback on topic Question about different tire sizes
I wouldn't worry too much about small size difference as you shouldn't use 4wd on hard surfaces and when you're on soft surfaces the wheels can slip enough anyway. However, I would always aim for matching to save the windup hassle.
15 Sep 2013 14:50 #83253
+1 but if you can closely match overall diameters, a few mm is all I mean, you might pull it off as tyres wear differently front and rear anyway.
Replied by helijohn on topic Question about different tire sizes
kirkynut wrote: You need to have the same size tyres front and rear
15 Sep 2013 15:22 #83262
by kirkynut
The proof of the pudding is in the eating but I fear it will be an expensive pudding!
- ellisthomas
15 Sep 2013 17:52 #83282
by ellisthomas
Replied by ellisthomas on topic Question about different tire sizes
Thanks for the help. Will 205/70's on the rear be ok with 195/70's on the fronts? I've been asking people I know and I can't get a straight answer. One person will say no I'l crash and die in a burning ball of Jimny and another will say no it's fine and if not better.
Thanks again.
P.S I'm mean 205/70's not 205/80's.
Thanks again.
Time to create page: 0.099 seconds
