linking batterys info wanted
- winter
13 Sep 2013 19:23 #83076
by winter
linking batterys info wanted was created by winter
hay guy dose anyone know if you can link two diffrent size batterys one being my st jimny battery linked to a bigger battery with 90ah and 850cca or do the batterys both have to be the same size any help be good tar
- Shep
13 Sep 2013 20:50 #83087
by Shep
Replied by Shep on topic linking batterys info wanted
I have the standard jimny battery linked to a 150amp deep cycle battery using a VSR type isolating system and it works without issue
- Lecras
13 Sep 2013 22:20 - 13 Sep 2013 22:21 #83093
by Lecras
Replied by Lecras on topic linking batterys info wanted
You can keep the same voltage by putting them in parallel.
Cant see any problem with different size batteries apart from one will take longer to charge than the other!
Last edit: 13 Sep 2013 22:21 by Lecras. Reason: Fat fingers
- winter
13 Sep 2013 22:31 #83094
by winter
Replied by winter on topic linking batterys info wanted
ok thanks vsr type isolating system is that a split charge system?you any pics
Shep wrote: I have the standard jimny battery linked to a 150amp deep cycle battery using a VSR type isolating system and it works without issue
- winter
13 Sep 2013 22:38 #83095
by winter
linking up without splitcharge system ! am i right in thinking you wire the +2+ -2- so battery are linked then run winch wires to the larger battery of the two in the back of truck with cut off switche on the winch +line :S
- Yellostreak
13 Sep 2013 23:39 #83102
by Yellostreak
Replied by Yellostreak on topic linking batterys info wanted
I used to work in emergency lighting plus I,ve messed about with camper vans and such in the past..
Basically you can connect for example a 100ah and an 85ah battery in parallel and both will charge but the 100ah will only every chare to 85% capactity (85ah) since the internal resistance of the 85ah battery starts to act as a load on the 100ah battery...
If you want to have 100 and 85 ah batteries both 100% charged then you need a split charge system. you can either pick up a signal from the alternator and trigger a relay to the second battery or use a smart com relay with a larger relay to charge the second battery..
If interested I can draw up some diagrams but to be honest just get the bits and it all comes clear fairly quickly..
Time to create page: 0.090 seconds
