Vacuum hubs
- Leech
31 Aug 2013 22:19 #81763
by Leech
Vacuum hubs was created by Leech
Hi,
I'm new to the site and would like some help PLEASE. I recently bought a 1999 jimny, and have just found out (after getting stuck) the hubs are not locking when selecting 4 wheel drive. I have no flashing light and the transfer box seems to be working fine ( I can hear it, and the front prop engages), also there is plenty of vacuum on all 4 pipes at the hub. I understand I can get manual ones, but I was wondering how much of a job, servicing the vacuum hubs would be.
Any help would be much appreciated
Thanks
Andy
Thanks
Andy
- markyp2000
31 Aug 2013 22:35 #81767
by markyp2000
Replied by markyp2000 on topic Vacuum hubs
The front wheel bearing seals is what seals the air to make the hubs work
Remove the black locking hubs see if thay are free a 12sided 8mm socket fits the torques/star bolts you can pull then on and off with your finger
When putting in 4wd do you here a click click from the front may need some one to put in 4wd while you put an ear to the hub
And make shore the pipes are the right way round as one hub may be being sucked on and the other sucked off
- Leech
31 Aug 2013 22:43 #81768
by Leech
Replied by Leech on topic Vacuum hubs
Thanks will have a look in the morning
Andy
Andy
- Leech
12 Sep 2013 20:08 #83005
by Leech
All sorted now thanks, the hubs are working fine. The problem turned out to be a blocked pipe (the bottom one). Tried removing the bottom hose and connecting a spare piece of pipe on the nipple and blowing with a foot pump, but even that wasn't enough. So I put a piece of tie wire in, and that cleared it. I could suck/blow with no problem, (with the hub removed).all I need now is the snow!!
13 Sep 2013 03:15 - 13 Sep 2013 03:16 #83025
by kirkynut
Replied by kirkynut on topic Vacuum hubs
Don't be wishing winter along so quickly! Snow is fun in a Jimjam but we don't want it just yet!!!
Glad you got your hubs fixed though! If they cause you any more trouble get fixed ones or manual free wheeling ones and spacers can be got from Jimnybits.
Last edit: 13 Sep 2013 03:16 by kirkynut.
The following user(s) said Thank You: Leech
- Albanianjimny
13 Sep 2013 14:46 #83064
by Albanianjimny
Replied by Albanianjimny on topic Vacuum hubs
i had the same problem as you when i first bought my jimny last winter. i kept reading everything on the net and asked everybody arround forums. i ended up switching to manual hubs. you can buy them new or get them used from a suzuki vitara or samurai (as long as they are manual locking hubs). you also need to buy 6mm thick spacers and it works like a dream, it never leaves you stuck and its reliable. you can open the hubs, seal them , grease them etc..
i highly recommend it to you. finding the leak is one thing, repairing it is also another thing. the big magic in all this is that it will leak again. look at all the forums, all the newbies, all talking about AWWW, MY VACUM HUBS...do yourself a favor ! you havnt bought a jimny for having the luxury of a range rover vogue so...
Time to create page: 0.095 seconds
