Suspension bump stop?
  • Rodden87
22 Aug 2013 06:33 #80707 by Rodden87
Suspension bump stop? was created by Rodden87
I'm currently running 31's on a 4.5 lift. I still have my anti roll bar on, but want to remove it to help flex and ride comfort. I'm worried that when I do the fronts will rub if I steer when flexed!
The only answers I can think of is more trimming and bashing or extended font bump stops but when having a look around I can only find one supplier zanfi does anyone know if anyone else does any or got any other answers?
  • markyp2000
22 Aug 2013 09:01 #80720 by markyp2000
Replied by markyp2000 on topic Suspension bump stop?
How about bolting this to the axle inside the spring ebay number 200953020712
Message them to get a size
  • Rodden87
22 Aug 2013 15:32 #80749 by Rodden87
Replied by Rodden87 on topic Suspension bump stop?
I think it would be perfect for the back but not the front as the factory stop is at the top and would rather not have rubber to rubber if that makes sense!
  • markyp2000
22 Aug 2013 15:36 #80750 by markyp2000
You can buy spacers for the rear bumpstops as for the front i think thay are welded on
  • TomDK
22 Aug 2013 15:47 #80751 by TomDK
Replied by TomDK on topic Suspension bump stop?
I'm planning on fitting LR bumpstops like this one, to the bottom of the chassis, so it hits the top of the axle tubing. Right next to the spring mount.
www.ebay.com/itm/330966503858
  • Rodden87
22 Aug 2013 16:20 #80754 by Rodden87
Well if they are welded then it might have to be a spacer at the bottom then! I'm going to have roll bar off tomorrow and have a proper look! Hopefully come up with something!
Time to create page: 0.084 seconds
