On board Computer
Got to thinking what about a computer for push bikes fitted to my Jimny.
Cheap, work wirelessly, gives max speed, average speed, time for the run and probably a lot more.
Any ideas where I could fit the two part sender out of harms way?
www.obdtool.co.uk/wholesale/v-checker-vc...3ijLkCFRMPtAod23oALw
Rhinoman wrote: Why not get a V-checker or scangauge?? I had an A301 on a Jimny, there are posher models available now:
This is what I want will look in more detail later.
- JerseyJimny
jimkyx wrote: I miss the on board computer on a previous car.
You would need to attach the magnet to the flange of the output shaft on the transfer box.
Then fit the pickup somehow to the transfer box, and bring the wire up inside the console.
Don't even think about the wireless ones, they need a battery in the sender, and I've never got a cheap one to work reliably on a pushbike.
Also you may find it simply doesn't have the setting range to get the speed accurate.
you might be better off with one of the gps cycle computers, they do the same sort of thing, and keep a log of your position and speed, and they do work.
High end units can also navigate with the right maps.
Get a couple of mounts, and you can use it on your 'bike as well.
I have a Garmin Edge 705 for my 'bike, it would work in a car no problem, shows pretty much anything you want, from sunrise to compass heading
- distantcamera
