Towbar?
- Rodden87
12 Aug 2013 22:23 #79723
by Rodden87
Towbar? was created by Rodden87
Can any one advise me on the best towbar? I will mainly be using it for recovery so would like a a 3.5 ton pin hitch if possible? I won't be doing much towing just a small trailer to the local tip!
Any advice appreciated!
- supergaz
12 Aug 2013 22:36 #79724
by supergaz
Replied by supergaz on topic Towbar?
All the branded towbars are type approved and so will all be of good quality.
Be carefull which ball and pin you choose, as fitting it to a non commercial vehicle means it must also be type approved.
12 Aug 2013 23:40 #79725
by Busta
I am very pleased with my tow-trust (£107 on ebay with wiring kit) but it sits below the bumper so may get in the way if you're doing any extreme off-roading. It might be worth finding which ones sit higher up, behind the bumper.
On the plus side you can fit it without removing the bumper!
13 Aug 2013 11:47 #79749
by facade
I got one of those, how did you manage to fit it without removing the bumper?
The captive nuts have to be inserted into the chassis rails from the ends.
The towbar makes it impossible to change the rear silencer without removing the bumper as well
13 Aug 2013 16:39 #79764
by Busta
They do and there is enough room to get them in with the bumper on. Everyone asks this. I can't seriously be the first person to have read the instructions and fitted it without taking the bumper off can I?!
I've just had a look under mine and I'm fairly sure the rear silencer will come out fine so maybe I have a different towbar to you.
facade wrote: I got one of those, how did you manage to fit it without removing the bumper?
13 Aug 2013 17:58 - 13 Aug 2013 18:01 #79771
by facade
The reason the silencer won't come off mine is the top rubber holder upper bush is inaccessible, and you just cannot move the silencer far enough to detach it.
Dead easy with the bumper off though. Have to say I didn't read any instructions when fitting the towbar, just followed an assembly diagram. The captive nuts were on lolly sticks and were a lot easier to position with the bumper off.
Only takes 10 minutes to detach the bumper, (and 1/2 a day to put it back, as there is always some hidden rust to clean up/repair/fill/paint at the corners of the tub. :huh: )
Last edit: 13 Aug 2013 18:01 by facade.
Time to create page: 0.113 seconds
