tipping
  • Poyner111
02 Aug 2013 14:44 #78776 by Poyner111
tipping was created by Poyner111
Does anyone know as a rough guide how far you can get a Jimny over before it goes over !!
  • barnes
02 Aug 2013 14:56 #78778 by barnes
Replied by barnes on topic tipping
As soon as your wing mirror touches the floor you have officially tipped anything before that youll be fine:p
02 Aug 2013 18:02 #78801 by kirkynut
Replied by kirkynut on topic tipping
Do you mean a standard truck as most are modified and it will differ between each one as there are so many different variables.
You're arse will tell you long before you tip it that things are not well with plenty left to go!
02 Aug 2013 18:27 - 02 Aug 2013 18:35 #78803 by Busta
Replied by Busta on topic tipping
A bog standard Jimny would be close to 45 degrees if stationary. Add a lift kit, roof rack, passengers etc and it will be several degrees lower. Factor in that you are probably moving and might hit bumps etc, and 30 degrees is a pretty safe working limit. Chances are you'd already be shitting yourself at 30 degrees anyway.
Stolen from another forum.
Not a Jimny obviously, and I suspect the Jimny angle would be slightly lower, but definitely over 40 degrees.
Last edit: 02 Aug 2013 18:35 by Busta.
  • mudman
02 Aug 2013 19:44 - 02 Aug 2013 19:49 #78808 by mudman
Replied by mudman on topic tipping
trust me your ass will tell you when its going to go........... my ass tells me at least once a month, iv had mine a long way over with out it going, total off road have some good pics but not sure witch month it will be in but your know the pic as soon as you see it........
e.g not an ass moment
keep an eye on TOR mag for ass moments :lol:
Last edit: 02 Aug 2013 19:49 by mudman.
  • supergaz
03 Aug 2013 21:56 - 03 Aug 2013 22:01 #78893 by supergaz
Replied by supergaz on topic tipping
I got into an awkward position at a photoshoot and had no handbrake as the rear drums were full of crud and I suprized some Jeep owners with the angles that the jimny can handle, along some stupidity.
This was a steep bank and I could not get reverse to re-position as I had my feet hard on the brakes, so the only way was down.
I now have rear disk brakes so my handbrake holds well after playing in the mud.
Last edit: 03 Aug 2013 22:01 by supergaz.
Time to create page: 0.114 seconds
