Corrected radius arms..
- Yellostreak
30 Jul 2013 15:55 #78604
by Yellostreak
Corrected radius arms.. was created by Yellostreak
Ok.. so i'm working out if the tower(dear wife) will give me clearance to go higher than a 2" lift which obviously means new radius arms (unless someone is selling some used ones cheaper!) and increased cost..
what I am trying to work out is if apart from strength and good looks do I actually need the rear ones.. since there is no steering there is no castor angle so there is no need to correct it - right?
I can see that the nose of the diff will be higher so the oil distribution/level may vary but other than that what's the issue with staying with standard arms?
- markyp2000
30 Jul 2013 16:21 #78607
by markyp2000
Replied by markyp2000 on topic Corrected radius arms..
Other than the prop joints being at a different angle i dont see a problem
- Yellostreak
30 Jul 2013 16:26 #78608
by Yellostreak
Replied by Yellostreak on topic Corrected radius arms..
I guess the prop joints will be 'bent' more from being straight if the castor is angle is corrected on either axle..
the only other issue I thought about is the rear springs being bowed without correction
- vitara_mad
30 Jul 2013 16:39 #78610
by vitara_mad
Replied by vitara_mad on topic Corrected radius arms..
the only thing without rear corrected arms is the springs being bowed but most can live with that so rear arms are not 100% needed but just a good idea if you can
- reaper
31 Jul 2013 11:58 #78653
by reaper
Replied by reaper on topic Corrected radius arms..
Due to cost I stuck with stock arms but put cc bushes in the rears. . Not perfect on a 4" lift but better than nowt
- Yellostreak
08 Aug 2013 09:02 #79333
by Yellostreak
yeah I guess if the springs are bowing because the castor is not corrected then first opportunity they have they will jump out and not return.. think its all 4 corners then the job is done!
