cracking the track rod end
  • helijohn
16 Jul 2013 16:38 #77217 by helijohn
cracking the track rod end was created by helijohn
I thought I had this mastered back in the 20th Century but it has caught me out today so what do you do??
I cleaned up the threads to remove the nut completely. Was a time when I used to leave the nut on, back in the Ark. I was happily unscrewing the nut when the joint let go so there I was with a half off nut. I got it off after almost an hour of struggling in this heat. At least I didn't have to crack the joint. :laugh: :laugh:
What do you do?
  • markyp2000
16 Jul 2013 17:20 #77233 by markyp2000
Replied by markyp2000 on topic cracking the track rod end
Put a trolly jack under it to push the taper of the joint back into the tapered hole
  • helijohn
16 Jul 2013 17:34 #77242 by helijohn
Replied by helijohn on topic cracking the track rod end
markyp2000 wrote: Put a trolly jack under it to push the taper of the joint back into the tapered hole
I did, well similar, used a scissor jack and virtually lifted the front end of the Jimny up on the joint. Still slipped. :angry: I think maybe some of the plus gas I'd put on the threads a while before had gotten into the taper. It had really caught me with my tapers down. :laugh: :laugh:
  • markyp2000
16 Jul 2013 17:44 #77249 by markyp2000
We use a tall axle stand at work and lower the car down on it and some times the car is off one of the ramp pads and it still moves then we get a looooooonngggg pole and use some elbow grease and leaver it up
  • helijohn
16 Jul 2013 18:14 #77256 by helijohn
markyp2000 wrote: We use a tall axle stand at work and lower the car down on it and some times the car is off one of the ramp pads and it still moves then we get a looooooonngggg pole and use some elbow grease and leaver it up
Pains ain't they. :laugh: :laugh:
16 Jul 2013 21:29 #77283 by facade
Replied by facade on topic cracking the track rod end
Mine were trouble too, I don't think suzuki make a very good taper ;)
I wirebrushed the exposed thread, and I ran a dienut down until it hit the nut, and they still go round before the nut comes off :angry: so I cut the nuts off :ohmy:
Then getting the new ones on was fun, I use a load of washers under the nut so it will tighten up solid before the nylock engages and seat the taper, then remove nut and washers and refit. It frees itself about half a turn before the nut tightens, so it is out with the jack, I don't like this as I think it will distort the weedy plastic socket in the joint and make it wear out faster, but I couldn't do it any other way.
Time to create page: 0.113 seconds
