front panel under bonnet
- i5jimny
15 Jul 2013 09:36 #77094
by i5jimny
front panel under bonnet was created by i5jimny
Should the front panel in front of the radiator when you lift the bonnet be the same colour as the rest of the body, my car is black but this panel is not and it is pretty rusty, would this point to accident damage and beena replacement panel?
- vitara_mad
15 Jul 2013 09:48 #77096
by vitara_mad
Replied by vitara_mad on topic front panel under bonnet
yes they are normaly the same colour as the rest of the jimny
- i5jimny
15 Jul 2013 09:57 #77098
by i5jimny
Replied by i5jimny on topic front panel under bonnet
Thanks for that info vitara. Possible it has had new panel then, also had 2 new front shocks and wheel bearing though I'm not sure if front or rear. Is this normal on a car that has just turned 27000? I would have thought they would be harder wearing unless seeing a lot of off road use.
- vitara_mad
15 Jul 2013 11:01 #77103
by vitara_mad
don't think there is any set time or mileage for bearings & shocks all depends on how its been used & if its been in a accident then they could have been changed cus they was damaged
- i5jimny
15 Jul 2013 11:36 #77107
by i5jimny
Hopefully not been in accident but all will be revealed as the garage that is going to do the crankshaft pulley (My other post in technical) carry out a safety check on vehicles that they recover so I'm pretty sure they will tell me all is ok.
15 Jul 2013 16:36 #77130
Replied by helijohn on topic front panel under bonnet
Do you mean what I call the slam panel cos mine is different and looks like it is original. I didn't let it concern me as it looks like OE spec. :laugh:
Time to create page: 0.133 seconds
