Help with head
  • Dalby
07 Jul 2013 21:47 #76382 by Dalby
Help with head was created by Dalby
Hi just got a second hand head off vitara mad of here thanks mate would you guys recommending head skim and pressure check before I put it on ? Or just clean up and put on
  • helijohn
07 Jul 2013 22:21 #76385 by helijohn
Replied by helijohn on topic Help with head
Dalby wrote: Hi just got a second hand head off vitara mad of here thanks mate would you guys recommending head skim and pressure check before I put it on ? Or just clean up and put on
Can't speak for Jimnys but every other head I have removed, and it ain't many, I have had skimmed. Someone will come along soon with Jimny recommendation I expect.
  • Dave cc
07 Jul 2013 22:35 #76390 by Dave cc
Replied by Dave cc on topic Help with head
if it aint bent then why skim it ??????????
If its bent and you skim in essence your camshft will also be running in bearings that are not inline although the face will be flat
Just straight edge it if it looks ok clean the faces up nice and fire it on with a new gasket
Also having it skimmed will raise your compression and that can also lead to more problems
  • helijohn
07 Jul 2013 23:19 #76396 by helijohn
Dave cc wrote: if it aint bent then why skim it ??????????
Can't speak for Jimnys but that's usually the problem with used heads.
  • Dalby
08 Jul 2013 06:50 #76403 by Dalby
Replied by Dalby on topic Help with head
I was thinking this if it ain't ever over heated and I put straight edge on I don't see why not
