Winching with one battery
- Teds Jimny
03 Jul 2013 19:37 #75987
by Teds Jimny
Winching with one battery was created by Teds Jimny
I am told that my standard battery won't be powerful enough to be used with my 9500lbs winch, iits on a ORA hidden winch mount, does anyone know whether one standard battery is enough, or do I need two? If so, would it fit in the engine bay?
I thought if the engine was running with lsome revs, the battery would be more than capable? I may be wrong
- TomDK
03 Jul 2013 19:42 #75988
by TomDK
Replied by TomDK on topic Winching with one battery
It all depends on your needs. But to get most out of your winch, you'll need a battery with as high a CCA rating as possible. Preferably 800-1000 CCA. Numax batteries are good on a budget. You don't need 2 batteries for decent winching power.
And yes, the standard battery will do the job. But a better battery is recommended.
- markyp2000
03 Jul 2013 19:51 #75991
by markyp2000
Replied by markyp2000 on topic Winching with one battery
Did you get any instructions with the winch
- supergaz
03 Jul 2013 19:52 #75993
by supergaz
Replied by supergaz on topic Winching with one battery
www.jimnybits.co.uk/shop/jimny-second-battery-tray/blog_27.html
I just got the prototype from Jimnybits and its great!
- Basketcase
03 Jul 2013 20:51 #76004
by Basketcase
Replied by Basketcase on topic Winching with one battery
The standard battery does do it ok but I wouldn't advise a lot of winching make sure you keep the car running you can notice the loss of battery power when you're winching under a heavy load
Time to create page: 0.143 seconds
