Stock Jimny and Rivers
- Nef
18 Jun 2013 17:15 #74281
by Nef
Stock Jimny and Rivers was created by Nef
Quick question about Jimny's.
They aren't available where I am (Canada) so I have to turn to the wisdom of the internet for help.
I'm going to be in Iceland this Summer and currently have a Jimny selected as my rental car because I want to drive on what they call "F" roads, which are gravel and unmaintained.
One road in particular I want to drive has some river crossings that don't look too deep or fast moving but what is an acceptable depth for me to try in a stock Jimny? How high off the ground is the air intake, without a lift or tire change?
Thanks in advance.
Here's a youtube link of a Discovery doing the particular road.
Thanks in advance.
18 Jun 2013 17:42 #74283
Replied by mlines on topic Stock Jimny and Rivers
The air intake is located up under the front wing (Fender).
On a UK spec. Jimny this is on the Right Hand side as you sit in the car (left hand side as you stand in front of the car looking at it). I have no reason to believe this is different on left hookers.
It creates a nice air pocket for itself if you keep moving so you can push your luck to the lip of the bonnet (hood).
The drivers manual is more conservative and suggests a lower level.
- JuanGuillie
18 Jun 2013 17:43 - 19 Jun 2013 13:07 #74284
by JuanGuillie
Replied by JuanGuillie on topic Stock Jimny and Rivers
Your air intake is in/under your right wing, behind the inner wing.
This is about a little bit higher than the top of your tire... BUT....
There are some précautions to take :
- How strong is the rivercurrent... if you can't get trough on foot staying upright due to the current don't go trough whit your car and make a detour.
- If you are not sure about the depth of it, go yourself into the river (on foot) and check which traject you should take.
- Look out for big boulders hidden under the watersurface.
- Drive gently into the water and try to keep a slow but steady "speed", before you get into the river look for a good way out at the other side of it.
- Look out NOT to make a wave in the front of your car, when this is flooding your bonnet your air intake and motor will be soaked.
- When you have a wave in the front of your car and you're reaching the other side the "wave" can come back to you.
- Use your common sense.
- Have lot's of fun...
Last edit: 19 Jun 2013 13:07 by JuanGuillie.
- Nef
18 Jun 2013 23:28 #74330
by Nef
Replied by Nef on topic Stock Jimny and Rivers
Thanks for the quick answers guys, as well as the tips for crossing water.
On a stock Jimny the top of the tire is around 670mm (based on a tire size calculator). So I guess I'll check the depth and hope we find it to be less than that.
19 Jun 2013 07:10 #74338
I hope you realise that by logging on to this forum that you have committed to show us the photos!
I bet when you first drive it you will think how can the Europeans drive such a basic, bouncy and rattling car. Then when you finish your holiday you will want to pack it in your luggage and take it home with you.
19 Jun 2013 11:45 #74365
by kirkynut
Replied by kirkynut on topic Stock Jimny and Rivers
Be aware that Jimnys float more than LRs so any real current will take you off for a ride you didn't expect!
Time to create page: 0.313 seconds
