Diff level plugs
10 Jun 2013 11:11 #73383
Diff level plugs was created by helijohn
Why is it always the same - I get a Suzuki second hand and I can never get the level plugs off to check the diff oil level. They have either never been checked for years so are almost welded in place or have been checked and whacked up tight by a really strong garage mechanic.
Even when new (and I have had precious few of those) some of the screws are so tight it's unbelievable. :woohoo:
Does anyone have any hints please before I put the impact air wrench to work? The front one already looks like a torx socket and I haven't even been near that yet. :laugh:
- adamatdraycott
10 Jun 2013 11:21 #73386
by adamatdraycott
Replied by adamatdraycott on topic Diff level plugs
The diff and gearbox/tbox plugs are all 10mm square drive
You can use a 3/8 ratchet head but be careful not to round the holes!
- markyp2000
10 Jun 2013 12:05 #73392
by markyp2000
Replied by markyp2000 on topic Diff level plugs
Heat it up a little
10 Jun 2013 16:55 #73417
I started to use a 3/8 extension bar but it was beginning to turn so I stopped before I rounded it. I have a 10mm sump plug head but it was starting to turn too.
I did think of that - I always reach for the blowtorch in the end but I am tempted to try to drift it round with a chisel first.
Why are they always done up so tight, arghhhhhh. I have the front to do after and it is in a mangled state already.
If these are this bad I am dreading the transfer box.
Replied by helijohn on topic Diff level plugs
adamatdraycott wrote: The diff and gearbox/tbox plugs are all 10mm square drive
Heat it up a little
10 Jun 2013 20:08 #73434
by facade
Replied by facade on topic Diff level plugs
10 Jun 2013 20:11 - 10 Jun 2013 20:14 #73435
It's a nice fix, I'll try it if I can get the *****out - looks like the chisel tomoz. :laugh: :laugh:
Or grind a few flats on the plug!!
facade wrote: Mine came out easy with a few taps from a chisel.
Then I got the welder to it and fixed it up good
Last edit: 10 Jun 2013 20:14 by helijohn.
Time to create page: 0.104 seconds
