oil
- owen
08 Jun 2013 19:06 #73188
by owen
oil was created by owen
hi all couple of questions 54 plate mode what oil do i use can i get any sort of workshop manuel and how much for a water pump and a thermostate as ive got overheating issues thanks all
08 Jun 2013 19:17 #73192
by kirkynut
I use 10w40 semi synthetic in my 2000 twin cam and see no reason for it to be different on a 2004 twin cam or single cam.
For a water pump and Thermostat pop to your local motor factor. Consider the radiator too, whether simply replacing it for about £100 or flushing it through in both directions with a good hose.
Also check your viscous fan's viscous clutch is working as it should - search on here for previous threads on it. Maybe lock it up completely if it's questionable. You might even consider an electric fan replacement but how you'd get it switched at the right temperature I don't know. There are several options which include probes in the coolant and probes in between the radiator fins.
09 Jun 2013 11:32 #73253
by facade
10/30 preferred in a vvt, they like the thinner oil to make the vvt do its vvt thing.
10/30 is recommended for all jimnys, although the manual allows 10/40. I use 10/40 semi-synthetic as it is easy to get hold of cheaply.
5/30 won't hurt, the first number is the cold cranking resistance.
- Johnniehec
- Thank you received: 56
10 Jun 2013 21:40 #73454
by Johnniehec
Replied by Johnniehec on topic oil
Castrol GTX special offer at Asda again, £12 all grades.
John.
John.
- owen
11 Jun 2013 18:27 #73510
by owen
Replied by owen on topic oil
thanks folks for your help
Time to create page: 0.095 seconds
