Experienceing something
  • Fran
07 Jun 2013 20:56 #73115 by Fran
Experienceing something was created by Fran
Hi guys I've just taken my jimmy out for the first time after putting 2'' lift big tyres as I was building up speed I noticed the car move slightly to left and right as if there was play in the wheel is this normal with lift and tyres. Or is it something else if u can help. I don't remember it doing it before the mod.
  • steffan
07 Jun 2013 21:55 #73117 by steffan
Replied by steffan on topic Experienceing something
I think you need to invest in the steering damper kit that's supposed to fix it
  • supergaz
07 Jun 2013 22:13 #73119 by supergaz
Replied by supergaz on topic Experienceing something
You need castor correction bushes. Its like your car driving on tip toes ;-).
Also consider rear shock relocation brackets.
08 Jun 2013 04:25 #73131 by Halford
Replied by Halford on topic Experienceing something
pop down to an ATS (one that does 4x4) and get your front wheels tracking checked
.... free check
and £30 to track
I've just had 1.5" lift and noticed steering slop and on left lock could feel the offside tyre dig-in as if the wheel was going buckle under me.
after tracking, it's soo much better and it was only just out of track
ROAD cars - need tracking, but the off-road crowd couldn't care less :whistle:
  • reaper
08 Jun 2013 08:58 #73148 by reaper
Replied by reaper on topic Experienceing something
That is not what a steering damper is for , by fitting one you will mask the problem not sort it out
As said get it tracked and ballenced . . . Also check tyre pressure you want to be around 22-26 psi
Ideally you will want castor correction to but try the cheep options listed above first :-)
  • Fran
08 Jun 2013 09:40 #73151 by Fran
Replied by Fran on topic Experienceing something
Thanks il look in to it when I get back I'm away for the week end
Time to create page: 0.142 seconds
