Internal and External cage.
  • Smoggy
03 Jun 2013 08:15 - 25 Jul 2013 14:58 #72564 by Smoggy
Internal and External cage. was created by Smoggy
A couple of weeks ago I went to ' my local fabrication guys. They made some cage suggestions for protecting me and my Jimny shell should I tip it over. They recommend linking a full 48mm external 6 point cage to an internal hoop with diagonal and 2x 45 degree stays again with diagonal (design like Renard's). The internal would pass through the floor and be welded directly to the chassis.
This is all great news for strength but I am concerned about the weight and would still like to be able to fit some sort of rear shelf and my recovery box in the rear.
Has anyone out there with an external cage or internal and external linked cage tipped their jimny over as I am intrigued to know how it fared. Like most of you out there I am unlikely to roll the car over and over at high speed as I only do laning and the odd pay and play. Mind you as some of the guys on here will testify I do suffer from the old red mist and have a go attitude when off road :laugh:
Last edit: 25 Jul 2013 14:58 by mlines.
  • markyp2000
03 Jun 2013 09:56 #72574 by markyp2000
Replied by markyp2000 on topic Internal and External cage.
Take a look at rhino rays cages thay are removable and have a x brace inside
He one had a guy who didnt belive it was upto strenth so while i was there with the owner he rolled it then the guy changed his mind and said it was upto the job lol
Theres so many cages out there its depend how deep ya pockets are but i would weld it to the chassis get a u plate made up that bolt through the chassis but then you have the problem of sealing the cage through the floor to the chassis
  • TomDK
03 Jun 2013 11:03 - 25 Jul 2013 14:58 #72577 by TomDK
Replied by TomDK on topic Internal and External cage.
Smoggy wrote: A couple of weeks ago I went to my local fabrication guys. They made some cage suggestions for protecting me and my Jimny shell should I tip it over. They recommend linking a full 48mm external 6 point cage to an internal hoop with diagonal and 2x 45 degree stays again with diagonal (design like Renard's). The internal would pass through the floor and be welded directly to the chassis.
As others and myself have written in others threads. RR looks a bit Agricultural. Don't know if looks are of any concern to you.
Lots of external rollcages are fitted 20-30 cm away from the body, which looks pretty silly if you ask me. Have also seen external cages with a much tighter fit, but not many of them, so don't know who makes these.
But The only cage that does what a cage is supposed to, protecting the driver, is an internal cage with diagonal tubing. I know that ORA are planning on doing an internal cage later this year. But perhaps Rob can give more info on this?
I'd try ORA first. Their designs are far superior to what RR makes.
You could also consider an OMP cage or the internal cage from KAP.
  • mudman
03 Jun 2013 15:36 #72599 by mudman
Replied by mudman on topic Internal and External cage.
iv got a KAP cage its very heavy to the point where 50mph is flat out any incline and you're in 4th gear and even on a quick gear change your at 40mph be time you're in 4th but i looks very neat cage sits so tight to the body that the roof rails have been removed worth looking in to but not cheap
  • Smoggy
03 Jun 2013 16:53 #72604 by Smoggy
Replied by Smoggy on topic Internal and External cage.
That Jimny is awesome. 3.9l V8 :ohmy:
  • RichiesJimny
03 Jun 2013 17:30 #72609 by RichiesJimny
Replied by RichiesJimny on topic Internal and External cage.
Make me laugh when I see people saying rhinorays gear is agricultural it seems people are forgetting their driving a jimny which is basically an updated samurai and not a modern highly sophisticated sports car :laugh: :laugh:
Time to create page: 0.099 seconds
