Camshaft position sensor
- MaxS
20 May 2013 17:40 #71162
by MaxS
Camshaft position sensor was created by MaxS
Hi all,
I've got a 2005 M13A (none VVT) hardtop Jimny.
a couple of days ago my car started behaiving weird, the rpm on neutral droped to between 250-500 rpm, when i accalerate it works fine, then it just wouldn't start at all, so it took me about 3-4 atempts in order to make it start.
today the check engine light turned on so I connected the OBD and it showed a P0340 code, which means the camshaft sensor or the wiring, the wiring is fine, i've checked it, but i wasn't been able to find a replacment sensor.
Does anyone knows if any other car sensor might fit so i can get some from a junkyard, or a link for purchasing a new one?
Thanx
Thanx
- Username
20 May 2013 18:58 #71178
by Username
Replied by Username on topic Camshaft position sensor
- MaxS
21 May 2013 05:08 - 21 May 2013 05:11 #71218
by MaxS
Replied by MaxS on topic Camshaft position sensor
It's not this one.
first of all it looks different, second it's a Denso sensor...
I've found some on ebay but none of them fits.
P.S. do not ship to Israel...
Last edit: 21 May 2013 05:11 by MaxS.
21 May 2013 06:42 #71222
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Camshaft position sensor
Think I may have one. Do you have the part number from yours so I can check?
Grey pick up Jimny
- MaxS
21 May 2013 15:29 #71268
by MaxS
the part no. is 33220 76G11
7601 03F17
This is what's writen on it.
7601 03F17
21 May 2013 20:05 #71301
by j999pre
Grey pick up Jimny
Ebay item no 380463087939
Brand new one from gsf
Just checked your numbers against mine its the same, unfortunately my spare one is for a vvt and is different.
If they won't post to you let me know.
Grey pick up Jimny
Time to create page: 0.091 seconds
