Wish me luck !!
- Maddscottish
17 May 2013 19:55 #70950
by Maddscottish
Wish me luck !! was created by Maddscottish
Well tommorow is the day iam going to tackle my leaking king pin bearing using the PDF from here :dry:
its made it look easy todo so wish me luck.
I have asked the fitters in the quarry todo it they said they were to busy
so am doing it right in the middle of the work shop so if a get stuck they will have to help me out to move it hahaha
- Bendywagon
17 May 2013 20:42 #70952
by Bendywagon
Replied by Bendywagon on topic Wish me luck !!
I done mine couple of weeks ago I'm a complete novice with spanners used the guide on this site and was pretty straight forward.the only problems I had were with corroded bolts which was a little time consuming.if you have any problems the people on here a great.
18 May 2013 06:42 #70968
If you are talking of the four bolts that retain the disk backing plate then you do not have to undo these. My guide is too detailed, you can pull the swivel apart by releasing the small bolts on the rear. However if you can undo these bolts then access is better
Sent from my HP Slate 7 using Tapatalk HD
- JivingDaddy
19 May 2013 05:28 #71033
by JivingDaddy
Replied by JivingDaddy on topic Bolts
A bit late, but good luck. How'd it go?
- Maddscottish
19 May 2013 14:15 #71053
by Maddscottish
Replied by Maddscottish on topic Wish me luck !!
Took me 5 hours but took time to check and re check the PDF instructions were great quite a easy job only problems i had were corroded bolts to but go there with them.
So all in all very happy next step will be fuel pipes.
Great Instructions thanks Martin.
- Tadpole
19 May 2013 17:47 #71070
by Tadpole
Replied by Tadpole on topic Wish me luck !!
Great news & well done you .................
Time to create page: 0.095 seconds
