Wanders at high speeds
- Lewisoffroad
17 May 2013 08:25 #70893
by Lewisoffroad
Wanders at high speeds was created by Lewisoffroad
Hello i've just started to learn to drive and when the jimny gets to anything about 45mph it unpredictable veers one way slightly and it takes all my concentration to keep it in a straight line.
We've got a 3" lift and Insa Turbo Sahara Mud Tyres. We currently have caster correction bushes but they're only for a 2" lift.
We wanted to know if buying the 3" radius arms would solve this problem at high speeds or would it be easier to get some smaller less agressive tyres for the time being.
Thanks!
Thanks!
- GuardianAngel
17 May 2013 08:28 #70894
by GuardianAngel
Replied by GuardianAngel on topic Re: Wanders at high speeds
Check your front wheel bearings and kin pins by jacking the wheel up and seeing if there is any play at 3/9 or 12/6 o'clock.
- gaz3359
17 May 2013 08:31 #70895
by gaz3359
Replied by gaz3359 on topic Wanders at high speeds
i had this although not that severe fitted a steering damper and it went away cheap easy fix for me.could be worth fitting one if not already fitted but as ga says bearing check first
- supergaz
17 May 2013 11:23 #70906
by supergaz
Replied by supergaz on topic Wanders at high speeds
Also i'd strongly recommend adjustable panhard rods.
- gus2000
17 May 2013 12:00 #70910
by gus2000
Replied by gus2000 on topic Wanders at high speeds
Yes, when the panhard rod is not horizontally causes many undesirable effects.
"A Panhard rod can be a simple and economical solution, but it's not a perfect one. To be effective, the Panhard rod and its mountings must be sufficiently rigid. The Panhard rod should be installed level, and usually it should be mounted as low as feasible. The rod itself should be as long as feasible. "
www.britishv8.org/Articles/Suspension-Design.htm
Install panhard relocation brackets...
Success
Gustavo
Success
Gustavo
- reaper
17 May 2013 20:53 #70953
by reaper
Replied by reaper on topic Wanders at high speeds
Also check your tyre pressure , recently had some new ones fitted and the jim tyred to kill me on the way back
45psi :ohmy: dropped em downt to 20 and it was back to normal
Time to create page: 0.094 seconds
