Which engine should i go for
- zain
14 May 2013 14:06 #70673
by zain
Which engine should i go for was created by zain
Hello Guys
i got a jimny wide
(as they call it ) recently and glad to find you folks. I have one question . My jimny has a G13BB model of engine , but it is in excellent condition . my jeep is 98 model japan manufactured one . I am thinking of an engine change.
which engine would suit me the best . I am located in a very hot part of Asia, and would that new engine give me more power and fuel efficiency ?
i got a jimny wide
- supergaz
14 May 2013 18:32 #70698
by supergaz
Replied by supergaz on topic Which engine should i go for
You want a G16b for an easy swap. Found in Vitaras and Balenos.
- zain
14 May 2013 19:33 #70708
by zain
Replied by zain on topic Which engine should i go for
thanks for the reply . i would be grateful if some body guide me whether a "M13AA" non vvt would be better or
not . I mean if i swap to the M13AA engine , shall the performance of my jimny would increase than the performance it is showing with its present engine
- supergaz
14 May 2013 20:10 #70716
by supergaz
It would be a wiring nightmare to swap to the M13aa, All wiring loom, ECU ect would all need changing. Might aswell just change the jimny for a newer model.
Much better just to swap for the G16b, that is the easiest option.
- zain
15 May 2013 04:15 #70746
by zain
Thank you sent for the reply
wont G16b ruin the off road ?, isnt it bulky to make the gemni front heavy
supergaz wrote: It would be a wiring nightmare to swap to the M13aa, All wiring loom, ECU ect would all need changing. Might aswell just change the jimny for a newer model.
Much better just to swap for the , that is the easiest option.
- supergaz
15 May 2013 05:37 #70748
by supergaz
The G16b engine is no bigger in size and will bolt straight in. That will give you the best gain without the headache. All I think you need is the original sump pan and oil pickup.
Time to create page: 0.092 seconds
