brake calipers
  • hypo81
08 May 2013 13:47 - 08 May 2013 13:49 #70269 by hypo81
brake calipers was created by hypo81
hi just wondering if there is a difference between RH and LH brake calipers
just as they look the same i have got the Aisin type ??
thanks in advance
Last edit: 08 May 2013 13:49 by hypo81.
  • Bodge
08 May 2013 14:50 #70276 by Bodge
Replied by Bodge on topic brake calipers
hypo81 wrote: hi just wondering if there is a difference between RH and LH brake calipers
thanks in advance
Just an educated guess (I don't have a Jimny), but I'd imagine the bleed nipples are at opposite ends between LH and RH. The nipples obviously always need to be in the uppermost portion of the caliper.
  • markyp2000
08 May 2013 15:45 #70278 by markyp2000
Replied by markyp2000 on topic brake calipers
thanks in advance
Calipers sit at the top of the disc not at the front and back like most cars
Thay willl fit if im right in thinking the pipe can fit both ways on the caliper
  • GuardianAngel
08 May 2013 16:29 #70280 by GuardianAngel
Replied by GuardianAngel on topic Re: brake calipers
thanks in advance
Yep the Banjo connector has two grooves to choose from thus making it possible to fit either side.
Its only the rear cylinders that are side specific.
  • hypo81
09 May 2013 14:38 #70337 by hypo81
Replied by hypo81 on topic Re: brake calipers
ok thanks for the help i have been lookin at them and they look as if they would go on ether side just wanted to make sure as they look the same ....
Time to create page: 0.090 seconds
