Engine management and immobiliser lights flashing.
- Blissett
03 May 2013 19:59 #69926
by Blissett
Engine management and immobiliser lights flashing. was created by Blissett
I know it's not jimny related but... The suzuki ignis has the same system and engine.. (m13a) After travelling about 40 minutes engine management and immobiliser lights start flashing and it stops..... Give it a few mins restart it goes on and some times stops.... Checked the logs for the ecu just the oxygen sensor for the cat was listed...
Any ideas??????
Just seems strange the immobiliser light flashes...
Thanks Mark
Any ideas??????
Thanks Mark
03 May 2013 20:11 #69927
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Engine management and immobiliser lights flashing.
Crankshaft sensor as per jimny engine. On the jimny its just under the alternator. Next time it does it cool with water (the sensor) then see if it starts straight away. Bingo time for new sensor. No codes probably recorded as the sensor sorts itself out once cool.
Grey pick up Jimny
- Blissett
03 May 2013 20:23 #69930
by Blissett
Replied by Blissett on topic Engine management and immobiliser lights flashing.
Thankyou...... Is it a dealer only part or can it be got from a motor factors???.
Wait a few mins with the engine off it starts.... So sounds the same...
Mark
Mark
03 May 2013 20:51 #69935
by kirkynut
Replied by kirkynut on topic Engine management and immobiliser lights flashing.
Dealer only, about £50 I think.
Time to create page: 0.086 seconds
