Corroded bolts
- Bendywagon
24 Apr 2013 12:52 #69373
by Bendywagon
Corroded bolts was created by Bendywagon
Bought my jimny two months ago and found that I need to replace king pins. Got the parts and everything was going fine until I needed to remove the backing plate behind the disk. Tried the other method of going at it from the rear, but all the bolts are completely corroded on both the retainer seal and the backing plate. I'm unable to remove them, and this means that so far I am unable to do the work needed. I am new to being a jimny owner and new to this site. Hope that someone out there can help me?!
- GuardianAngel
24 Apr 2013 13:31 #69374
by GuardianAngel
Replied by GuardianAngel on topic Re: Corroded bolts
Get yourself some Irwin Bolt Grippers. Best thing I ever bought. Has got every rusted and rounded off bolt on my J.
Machine Mart sell them.
- Bendywagon
24 Apr 2013 14:00 #69375
by Bendywagon
Replied by Bendywagon on topic Corroded bolts
Not sure if I'm doing this right only just got a computer.anyway thank you for your reply will deff look into getting bolt grippers.this sight rocks!.thanks Martin for the parts arrived quickly.
- Fyffe
24 Apr 2013 14:09 #69376
by Fyffe
Replied by Fyffe on topic Corroded bolts
The only thing i use is easy outs, WD40, and air chisels ive never been stuck once using them.
- markyp2000
24 Apr 2013 14:57 #69379
by markyp2000
Replied by markyp2000 on topic Corroded bolts
Where are you located some one may be on here thats in your area that could help
Best tip i could give is to use good 6 sided sockets not 12 sided ones and soak every thing and if in dought try to get some heat on it i use a blow torch that i got from a plum center that plummers use for soldering there pipe work
24 Apr 2013 16:39 - 24 Apr 2013 16:44 #69383
by facade
Replied by facade on topic Corroded bolts
Do you mean the circle of bolts with the arrows?
To remove the hub and change the kingpin you only need remove the steering link, brake calliper and undo the ring of bolts (only 2 are marked with arrows) remove the big dust seal, then undo the 8 bolts marked X and pull the kingpins out.
(You don't mess with the backplate, unless it is something to do with that new fangled ABS that newer cars have :ohmy: )
The swivel hub will pull off with the driveshaft still in, although we usually take off the freewheel hub and remove the CV joint circlip to get the driveshaft out and clean it.
Attachment kingpinhousing.jpg not found
Last edit: 24 Apr 2013 16:44 by facade.
The following user(s) said Thank You: Bendywagon
Time to create page: 0.096 seconds
