4w to 2w clutching problem
- pal911
21 Mar 2013 19:18 #66460
by pal911
4w to 2w clutching problem was created by pal911
I want to buy à 2005 jimny but there is à slightly problem.
When changing from 2w to 4w drive, everything Seems to function allright.
But while driving changing from 4w to 2w, i hear à loud bang from under the Car as if the 4w drive is released with many forces.
Is that à normal situation?
- adamatdraycott
21 Mar 2013 19:25 #66461
by adamatdraycott
Replied by adamatdraycott on topic 4w to 2w clutching problem
My 04 with a manual lever goes with a thud occasionally
Could be called a bang I suppose
- JivingDaddy
21 Mar 2013 19:36 #66462
by JivingDaddy
Replied by JivingDaddy on topic 4w to 2w clutching problem
My 2005 with a manual lever makes a reassuring subdued clonk, but no bang. :whistle:
- pal911
21 Mar 2013 19:37 #66463
by pal911
Replied by pal911 on topic 4w to 2w clutching problem
When changing to2w drive it also feels like driving thru à hole.
I thought it schould go in à smooth wat. Isn't that so?
- gus2000
21 Mar 2013 20:09 #66469
by gus2000
Replied by gus2000 on topic 4w to 2w clutching problem
For the configuration of jimny 4WD (rigid connection between the front and rear axles), this should not be used on hard surfaces, Otherwise, the difference between the two axes of rotation produces a twist angle in the propeller shafts, universal joints and shafts.
This twist angle produces an accumulation of energy in materials, which is released when disengaging the 4wd, This energy is transforming into a metallic noise "clanck"
I suggest testing the 4WD on sand, mud or soft ground
The use of 4WD on hard surfaces, damages severely the transmission
Gustavo
Gustavo
- gilburton
21 Mar 2013 20:14 - 21 Mar 2013 20:15 #66472
by gilburton
Replied by gilburton on topic 4w to 2w clutching problem
I was just going to ask that. Are you using 4wd on tarmac i.e. normal roads?? If so do not do it. Only off road or slippy surfaces.
Is it a manual lever or push button as this is the year they changed over?
Last edit: 21 Mar 2013 20:15 by gilburton.
Time to create page: 0.098 seconds
