diffs
- TomDK
19 Mar 2013 15:02 #66292
by TomDK
GL-4 oil is the correct oil for the T-box. But you can easily use GL-5 for the transferbox as well. No trouble with that. I do it my-self.
Replied by TomDK on topic diffs
adamatdraycott wrote: Unless you use this
www.morrislubricantsonline.co.uk/lodexol...thetic-gear-oil.html
Quoted as being suitable for API GL 1-5 (guessing because its SS?)
It can also replace 80W 90 in the diffs!
Don't buy off that site... they are hugely expensive compared to my local seller
- dirtydogz
19 Mar 2013 21:12 #66327
by dirtydogz
Replied by dirtydogz on topic diffs
/08/10 - Oils and Fluids
Category: Information Published on Friday, 06 August 2010 13:26 Written by Martin lines Hits: 3624
A number of people have asked for the following information.
From G13BB manual
Type Quantity Specification
Engine Oil 4.5 litres 10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.3 litres 75W - 90
Transfer Box Oil API GL-4 0.9 litres 75W - 90
Differential Oil (Front)
API GL-5 1.35 litres 80W - 90
Differential Oil (Rear) API GL-5 1.5 litres 80W - 90
Coolant Capacity 4.5 litres
From M13AA manual
Engine Oil 4.0 litres 10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.1 litres 75W - 90
Transfer Box Oil API GL-4 0.8 litres 75W - 90
API GL-5 1.1 litres 80W - 90
Differential Oil (Rear) API GL-5 1.3 litres 80W - 90
A/T Fluid/Power Steering Dextron IIE 1.1 litres
Brake Fluid DOT3
From G13BB manual
From M13AA manual
Brake Fluid DOT3
- gus2000
19 Mar 2013 22:53 #66340
by gus2000
Replied by gus2000 on topic diffs
In my jimny G13BB the front differential contains 1.9 l (fill it comes back out the filling hole)
Not know the cause
Write it to not forget
I entirely agree not to confuse oil GL4 with GL5, are totally different
The article or Richard Widman is perfect. thank you
I read it in Spanish in www.widman.biz/ .
Success
Gustavo
Success
Gustavo
- TomDK
19 Mar 2013 23:52 - 19 Mar 2013 23:58 #66344
by TomDK
Gus, where have I written that gl5 is the same as gl4?
Only thing I wrote is that gl5 is fine for tbox. And it is so because there are no synchromeshes or any other brass parts like in the gearbox. Gl5 contains additives that have a negative impact on the synchromesh.
So again, gl5 is fine for t-box.
Oh, and all this is also found in you widman link.
Last edit: 19 Mar 2013 23:58 by TomDK.
- gus2000
20 Mar 2013 00:28 #66345
by gus2000
Sorry Tom, I may not express properly (in English is difficult for me :dry: )
The t-case have brass synchromesh’s, it´s allowing connect front axle without stopping the car.
I modify my t-case, this demand and effort to satellites for which they were not designed. In this case use gl-5 oil. I prefer satellites long life at the expense correct synchromesh’s operation.
thanks
Gustavo
thanks
Gustavo
- adamjimny
20 Mar 2013 08:56 #66352
by adamjimny
Replied by adamjimny on topic Re: diffs
Rich you can use gl5 in your tranny with it being an sj box too so gl5 all round
Sent from my GT-I9300 using Tapatalk 2
