over heating
  • owen
03 Mar 2013 16:34 #64478 by owen
over heating was created by owen
help folks took my jimmney mode for a run to the midlands
from wales and it started to over heat after about a hour and stayed hot parked it up for a couple of hours then came home on the way home got hot again and just before i got home started to boil out of expansion tank any ideas plz new to these cars do you fill water into expansion tank ? or into top of radiator sounds daft but its different to all my other cars could it be that theres no water in rad also i had a look at engine when hot fan was working but did not seem to be going very fast help
03 Mar 2013 17:11 #64479 by facade
Replied by facade on topic over heating
How the jimny works is
The radiator is full of water.
When the engine heats up, the hot water expands so there is more volume.
The "extra" water goes to the expansion tank. (and the level rises)
When it cools down, the water goes back to the radiator.
So, when the engine is cold
Remove the radiator cap, and fill right up to the lower rim with coolant (50/50 antifreeze & water, or bought ready to use)
Replace the cap. and fill the expansion tank to the COLD line.
The level in the expansion tank may drop a little, as any air gets expelled from the radiator
As to the over heating,
Your radiator may be blocked with mud/dead things
Use a hosepipe not a jetwasher, spray the radiator from the fan side, and water should shoot out the front.
The fan belt may be lose/missing (but then the red light comes on)
The thermostat may be stuck
The radiator may have an internal blockage (replace it)
The fan may have missing blades
The viscous coupler unit to the fan may be faulty, usually the fan is very free and rocks from side to side.
Start with washing the radiator.
  • owen
03 Mar 2013 18:11 #64487 by owen
Replied by owen on topic over heating
thanks for a brilliant reply will try all of the above much appreciated
03 Mar 2013 18:25 #64488 by facade
No problem :)
In my post about the fan coupler, if it is working, the fan will turn by hand with some resistance, and won't rock from side to side.
If it is faulty the fan will spin easily and rock from side to side
  • owen
03 Mar 2013 18:46 #64490 by owen
just another thing mate could it be somthing nasty like head gasket hope not but asking just incase
03 Mar 2013 19:44 #64493 by facade
Yes it could, or a host of other things.
If it only does it on long fast trips I'd start with overhauling the cooling system though.
