abs sensor
  • ratman
22 Feb 2013 14:10 #63615 by ratman
abs sensor was created by ratman
well i have now worked out how to check the sensors with a multi meter......but here is the problem
Back sensor one reading 1.32 the other reading 1.34 and both the front sensors reading 1.27? multi meter set on omes arrow pointing at 20 k?
which sensor is faulty? all answers welcome?
if your write you win a prize......... a faulty sensor of your choice :laugh:
22 Feb 2013 20:47 #63672 by Rhinoman
Replied by Rhinoman on topic abs sensor
Can't tell from the readings, that tends to be the problem with these ABS sensors. Can you pull codes from the ABS ECU?
  • ratman
27 Feb 2013 08:40 #64107 by ratman
Replied by ratman on topic abs sensor
Hello "rino" i have tried to but my wee code reader is only engine management, im going to suzuki this sat as i have no other choice its driving me mad!
27 Feb 2013 12:26 - 27 Feb 2013 12:27 #64124 by Rhinoman
Did you check for the monitor coupler under the dash? If you're anywhere near North Wilts then I have all the dealer tools with suppport uo to 2010 models.
Last edit: 27 Feb 2013 12:27 by Rhinoman.
Time to create page: 0.077 seconds
